Pages (135): Previous 195 96 97 98 99135 Next
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 10:23 AM
oil sits at 80=85 degrees Celsius
Jimbob-T-Lex
09-06-2020, 10:23 AM #961
john wan
09-06-2020, 10:40 AM
Ooooo someones had a thermometer out ha ha ha is that high I havnt looked into it to be honest
john wan
09-06-2020, 10:40 AM #962
Jimbob-T-Lex
Moderator
1,674
09-06-2020, 10:45 AM
Na I have oil temp gauge lol na seems to be ok mate from what I searched on the net
Jimbob-T-Lex
09-06-2020, 10:45 AM #963
john wan
09-06-2020, 10:46 AM
Ah haaa
john wan
09-06-2020, 10:46 AM #964
Ah haaa
Jimbob-T-Lex
Moderator
1,674
30-06-2020, 12:22 PM
Well thought id update this thread aint been on for a lil while now!
Well the cheap turbo was on its last legs i could hear it scraping Sad I managed to source a new one very cheap but unfortunately its a garrett gt35 want a gt30 but couldnt refuse the price! £150 and the bloke had it checked to see if it was all fine
Well that is now being fitted and i have redone my oil drain so its a 12an screw fix now as i noticed it was leaking (could of been contributing to my crank case pressure??)
Also i have tidied alot of my engine loom wiring so that is clear of the rocker cover as it looked a mess, now it runs either side for the injectors and coil packs just waiting on some conduit now to complete!! well i could of done a little more but patience has run out lol
Wrapped my turbo manifold with titanium wrap to try and get rid of some of the heat from my engine bay felt extremely hot to the point you couldnt do anything under the bonnet for at least an hour lol
Not sure but i may sort getting my screamer plumbed back into the exhaust as it does get a bit much all the time lol but undecided
Push start button is in the post so that will get fitted when it arrives also
So basically im picking up my down pipe tomorrow then i can test all my wiring and make sure she starts. Then im doing a boost leak check and seeing if the pressure is gone from my crank case
Fingers crossed ill have the beast back on the road tomorrow!!! ill get some other pics 2moz these are a some i got last week
[Image: null_zpsae44e990.jpg]
[Image: null_zps2367b548.jpg]
[Image: null_zps07a2e177.jpg]
[Image: null_zpsc5ace788.jpg]
[Image: null_zps6abe492f.jpg]
[Image: null_zps8062be32.jpg]
[Image: null_zps2d186437.jpg]
[Image: null_zps45c8933c.jpg]
Jimbob-T-Lex
30-06-2020, 12:22 PM #965
30-06-2020, 01:00 PM
Looks good mate! Little tip I discovered the other day. Twist your injectors 180 degrees so the wirings underneath, simple but looks so much better!
30-06-2020, 01:00 PM #966
Jimbob-T-Lex
Moderator
1,674
30-06-2020, 01:40 PM
Mmmm I'll have a look tomorrow at that lol so simple as well
Jimbob-T-Lex
30-06-2020, 01:40 PM #967
Jimbob-T-Lex
Moderator
1,674
01-07-2020, 11:09 AM
Well got the beast up and running but I can hear air being drawn past my injectors so need to get new seals! Any one know the number for them or where to get some??
Just got to do the wiring conduit now and refit the screamer pipe then complete
Jimbob-T-Lex
01-07-2020, 11:09 AM #968
john wan
01-07-2020, 01:34 PM
40quid I think from lexus mate or if you go on ebay theres a guy mr injector I think his name is if you give him the type an number on your injectors he will match to what he has he quoted me 30quid I couldnt be arsed an went to lexus in the end
john wan
01-07-2020, 01:34 PM #969
Jimbob-T-Lex
Moderator
1,674
02-07-2020, 06:46 AM
Got the injectors to seal now so all is good, Ive got to now do a boost leak test and replace the 3" V band clamp as the old one is damaged. Also i noticed a little oil and water leak hopefully its the sump and not something serious so investigate them!
Car sounds very nice a few little noises that need sorting but think its my arch liner
Jimbob-T-Lex
02-07-2020, 06:46 AM #970
Views 5,138
09-04-2024, 01:09 AM
Views 1,292
06-04-2024, 05:57 PM
Views 102,903
25-03-2024, 02:10 AM
Views 9,103
23-03-2024, 03:45 PM
Views 20,421
18-02-2024, 11:42 PM
Views 405
18-12-2023, 02:55 AM
Views 1,491
08-10-2023, 03:59 AM
Views 6,022
06-10-2023, 02:58 AM
Views 3,144
04-10-2023, 03:52 PM
Replies 76
Views 2,822
30-09-2023, 01:24 AM
Last Post by RichS11
