Pages (135): Previous 196 97 98 99 100135 Next
Jimbob-T-Lex
Moderator
1,674
13-07-2020, 07:01 AM
Well the update is it is all up and running ok now after a mad rush as my dads soarers water pump went!
Managed to seal the injectors and do vacuum leaks and now i am getting no fuel cut issues the one thing which is down to turbo choice but couldnt turn down is the spool up time 1st and 2nd are quite sluggish but im thinking i will change the hot side from .82 to .57 to help spool up what people think? obv ill loose top end but found one for £90
Also now my mission is to try and use the 550cc injectors i had that were leaking i got new o rings and im gonna see how that goes hopefully ill sort that will save me £350 ill get some pics when it is not raining!!!
Jimbob-T-Lex
13-07-2020, 07:01 AM #971
13-07-2020, 10:22 AM
It's all about speed off the line lol
13-07-2020, 10:22 AM #972
Jimbob-T-Lex
Moderator
1,674
13-07-2020, 10:26 AM
Yeah mate exactly thinking the smaller hot side will help a fair bit
Jimbob-T-Lex
13-07-2020, 10:26 AM #973
Jimbob-T-Lex
Moderator
1,674
13-07-2020, 10:30 AM
Hows yours coming along mate?
Jimbob-T-Lex
13-07-2020, 10:30 AM #974
13-07-2020, 10:54 AM
All done mate I think. Just need the mapper to have another look and see.
13-07-2020, 10:54 AM #975
Jimbob-T-Lex
Moderator
1,674
13-07-2020, 11:01 AM
Nice mate can't wait to see it! Hopefully try sort my 550cc injectors tomoz if weather permits lol I've still got a fair bit to do just having the time at the minute oh and cash! The ecu is just going to have to wait!
Jimbob-T-Lex
13-07-2020, 11:01 AM #976
Jimbob-T-Lex
Moderator
1,674
31-07-2020, 11:38 AM
High all wonder if anyone can help would this housing fit my Garrett gt35
http://www.ebay.co.uk/itm/270879218082?s...1423.l2649
mine is 68 wheel diameter and 84 trim im not a turbo expert lmao thanks in advance
Jimbob-T-Lex
31-07-2020, 11:38 AM #977
Jimbob-T-Lex
Moderator
1,674
01-09-2020, 04:59 AM
well its been quite a while since i have been on here so its about time i give a little update sorted few bits lately
Sorted engine loom so nice and neat
fixed boost solenoid as had a break in cable
Intake air temp cable routed
new hella horns fitted
drilled and tapped turbo mount on manifold
Sourced material to make clutch cylinder shield (make 2 one for Stav)
I have still got to
Buy bigger injectors
Buy ally under tray
Standalone ECU Link G4 Storm
Fuel return line (been lazy)
fit new arch liners as mine are shot
finish off the 3" exhaust just back box and rear silencer delete to do
Uprated ARBs
Coilovers
Get rubber for new rims (after winter for sure)
Finishing touches all round
These bits all depend on money
Also debating to get rid of my CW replica front bumper and fit standard one with lip so it looks a cleaner finish as it is a royal pain to get the replica to fit nice and clean
Jimbob-T-Lex
01-09-2020, 04:59 AM #978
I have still got to
Buy ally under tray
Uprated ARBs
Coilovers
16-09-2020, 08:38 AM
how you getting on with it all now mate
16-09-2020, 08:38 AM #979
Jimbob-T-Lex
Moderator
1,674
24-09-2020, 07:19 AM
Well thought i better update seems i haven't been on here too much seems i am always on FB!
So lately i have bought a fair few bits:
RX8 Injectors 420cc so should handle OK
RX8 injector refurbish kit so all new rubber seals and filters
All the parts needed for fuel return line (about time!!)
Engine bottom covers
New arch liners
Greddy 3 Bar map sensor
[Image: Greddy_16401301_1_zps88de7eec.jpg]
Genuine side skirts
New alloys (fit after winter lol)
[Image: 1379738_222084161292115_1428357596_n_zps9b3fea57.jpg]
This lot should keep me busy over the Xmas period by this point the car should be running very smooth! well soon as i source the crank case pressure lol oh and sort my timing out ill explain i got an error code which related to cam position sensor and other bits so checked my timing and i am def 1 tooth out poss 2 which is never good and was definitely set right when i did my water pump so new tensioner and belt going to get fitted very sharpish!!!
ill get a Gd amount of pics on the go as well as its been a while and ill get on here a lot more!!
Jimbob-T-Lex
24-09-2020, 07:19 AM #980
New arch liners
Genuine side skirts
 6 Guest(s)
 6 Guest(s)
Views 5,138
09-04-2024, 01:09 AM
Views 1,292
06-04-2024, 05:57 PM
Views 102,903
25-03-2024, 02:10 AM
Views 9,103
23-03-2024, 03:45 PM
Views 20,421
18-02-2024, 11:42 PM
Views 405
18-12-2023, 02:55 AM
Views 1,491
08-10-2023, 03:59 AM
Views 6,022
06-10-2023, 02:58 AM
Views 3,144
04-10-2023, 03:52 PM
Replies 76
Views 2,822
30-09-2023, 01:24 AM
Last Post by RichS11
