JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Is300 What to look for
Chris0121
07-07-2019, 08:03 AM
I'm lookin at an is300 tomorrow and just want the basics on what to look for with it I'm gettin the cambelt and water pump done the day I get it if the car seems ok but just wanna know if there's anything else I should look out for
Chris0121
07-07-2019, 08:03 AM #1
07-07-2019, 08:22 AM
oxygen sensors seem to knacker up if its been sitting unused for a while so may need changing in the near future. then just general checks. if you have a scangauge connect that up make sure of no pending codes. test the tiptronic make sure the buttons change up and down, make sure sunroof works, listen for abnormal engine noises, make sure theres radiator fluid in the reserve reservoir.
07-07-2019, 08:22 AM #2
Chris0121
07-07-2019, 08:39 AM
is300_dino oxygen sensors seem to knacker up if its been sitting unused for a while so may need changing in the near future. then just general checks. if you have a scangauge connect that up make sure of no pending codes. test the tiptronic make sure the buttons change up and down, make sure sunroof works, listen for abnormal engine noises, make sure theres radiator fluid in the reserve reservoir.
Thanks mate not got a scan gauge =(
Is the reserve reservoir easy to see and got a fill line on it just so I know I know a bit about cars so can check most things just never looked over a Lexus properly before
Chris0121
07-07-2019, 08:39 AM #3
07-07-2019, 08:50 AM
yeah its behind the main rad and has a window with fill line, look down between the cams and the rad and you should notice it, you may need a rag to degrease the plastic window to see the lines if the engine bays not super clean
07-07-2019, 08:50 AM #4
Chris0121
07-07-2019, 09:01 AM
Thanks mate really lookin forward to it now =) its platinum ice just hope it goes well and I'd be able to get if Wednesday when the money clears for my mr2 =)
Chris0121
07-07-2019, 09:01 AM #5
Replies 128
Views 7,483
20-08-2020, 09:09 AM
Last Post by Fry-Up
Views 1,000
30-12-2019, 06:50 AM
Last Post by reco2k
Replies 29
Views 1,288
30-11-2019, 01:20 AM
Views 935
31-10-2019, 03:29 AM
Last Post by mike_01
Views 348
10-05-2019, 04:47 AM
Last Post by Fry-Up
Views 331
09-05-2019, 12:39 PM
Last Post by jasons
Views 832
26-04-2019, 08:05 PM
Views 664
04-04-2019, 03:08 AM
Last Post by is300_dino
Replies 26
Views 1,353
20-03-2019, 03:09 AM
