JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension soft brakes/pedal travel
01-11-2021, 11:35 AM
Bled the whole system with toxo the other day, made absolutely no difference. Fairly confident that all bubbles were removed. No leaks anywhere, fluid level is good. Is this likely to be a master cylinder problem?
Worth noting that I have ucf 20 4 pots on the front. Running out of ideas and it is getting annoying.
01-11-2021, 11:35 AM #1
01-11-2021, 01:14 PM
How old is the fluid? The fluid could be contaminated with water?
01-11-2021, 01:14 PM #2
01-11-2021, 01:24 PM
It's had an entire flush since the brake line was swapped a month ago.
01-11-2021, 01:24 PM #3
mattlaw
01-11-2021, 02:06 PM
The fluid is new Stav, he had a new bottle off me not long ago
mattlaw
01-11-2021, 02:06 PM #4
01-11-2021, 04:54 PM
The only way it'll be sponges then is if there's a leak or air getting in, could take the master off see if its wet behind it. Other wise check all the connections as tight with decent washers.
01-11-2021, 04:54 PM #5
01-11-2021, 10:36 PM
Will look again, but we checked all of the connections for any sign of leaks and they were dry as a bone. I reckon it's one of the front ones. Starting to annoy me now, doesn't feel that safe.
01-11-2021, 10:36 PM #6
04-12-2021, 06:10 AM
have you solved this mate cant have squidgy brakes lol
04-12-2021, 06:10 AM #7
rob
11-12-2021, 06:59 AM
Use a vacuum bleeder its so much easier and increased flow removed some trapped bubbles. But could also be the master cylinder. The workshop manual covers the test.
rob
11-12-2021, 06:59 AM #8
15-02-2022, 08:05 AM
Rabster have you solved this mate cant have squidgy brakes lol
No mate. I don't understand it to be honest, I'm not losing ANY fluid at all.
15-02-2022, 08:05 AM #9
lex2oos
28-04-2022, 04:50 AM
Friend of mine had the same problem. He bought master cylinder and brake booster and that solved it...
lex2oos
28-04-2022, 04:50 AM #10
Views 478
16-06-2023, 09:40 AM
Views 582
15-02-2022, 12:32 PM
Last Post by Lance79
Views 1,695
29-04-2021, 05:16 AM
Replies 34
Views 4,105
31-01-2020, 07:51 AM
Replies 29
Views 3,078
20-03-2019, 01:04 PM
Views 645
07-03-2019, 11:22 AM
Last Post by bash6673
Replies 24
Views 2,546
13-02-2019, 07:03 AM
Last Post by Phil01
Views 1,196
16-09-2018, 06:41 AM
Views 782
03-08-2018, 04:22 PM
