JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Sticking Brakes
Sticking Brakes
Sticking Brakes
Pages (4): 1 2 3 4 Next
01-03-2018, 12:48 AM
There are a lot of similarities between the front brakes on my MR2 and the front brakes on an IS200. Both are twin inboard piston sliding calipers, with similar carrier designs, similar sizes etc.
As the MK2 MR2 gets older more and more people are struggling with brake problems caused by poor maintenance. The boots and seals fail over time and you wind up with sticking or jammed pistons or sticking sliders. Both these problems cause the brake to be partially applied all the time, which leads to a tremendous heat buildup and massive brake wear. The excess heat can in turn can lead to warped discs, warped sliders, loss of power, loss of braking efficiency, MOT failure, and for those of you that are bothered about how clean your car is, loads of brake dust! Not to mention chewing through brake pads in record time.
Seeing as the IS200 uses the same caliper design, I'd expect to see this becoming more of an issue for IS owners over the next few years. Anyone had any problems with sticky calipers, failed slider or piston boots, etc?
01-03-2018, 12:48 AM #1
01-03-2018, 01:55 AM
mate i did my calipers last summer got the refurb kit did all all rubbers but now again for some reason the left front has started sticking again just not had the time to take it all apart yet :cursing:
01-03-2018, 01:55 AM #2
01-03-2018, 02:06 AM
I spent ages doing a full brake rebuild using the Toyota rebuild kits on the '2, I think 3 or 4 years ago. They lasted about 6 months! So I gave up and swapped the calipers for pro refurbed ones (well the rears anyway, the fronts have lasted a bit longer but are on the way out now).
01-03-2018, 02:06 AM #3
01-03-2018, 02:29 AM
yeah im on the look out for some supra or brembo front calipers so if any one knows of a set going for sensible money let me know lol cheers
01-03-2018, 02:29 AM #4
01-03-2018, 02:31 AM
Or LS400 brakes Wink
01-03-2018, 02:31 AM #5
01-03-2018, 02:33 AM
but you knew i knew that lol
01-03-2018, 02:33 AM #6
01-03-2018, 02:40 AM
Supra brakes do this too.. or at least both mine have
01-03-2018, 02:40 AM #7
01-03-2018, 03:03 AM
Only the lesser spec JDM brakes are the sliding caliper design on Supra, the larger JDM and UK spec brakes are fixed monobloc calipers so *shouldn't* suffer from these problems as much (less moving parts = less to go wrong).
01-03-2018, 03:03 AM #8
02-03-2018, 02:06 AM
Well, surprise surprise, got the brakes off Dan's IS200 last night and lo and behold sticking slider. The lower slider boot had failed and as a result the slider was so corroded into the carrier it took about 20 minutes with a hammer and a punch to try and coax the thing out!! It was totally rusted and misshapen all the way down. The small rubber bush was melted and about 1/3rd of the way down the slider, which isn't right either (it's supposed to sit in a recess cut into the end of the slider).
Fortunately it turns out that the brakes are so similar that the sliders, bush and boots are all exactly the same as the MR2 parts that I had in stock, so we could replace the lot with new parts there and then. Cleaned all the corrosion out of the carrier with a round file and plenty of lithium grease thrown in for good measure. Should be good for a few more years!
02-03-2018, 02:06 AM #9
02-03-2018, 03:15 AM
do u wanna do mine lol
02-03-2018, 03:15 AM #10
Views 451
28-04-2021, 12:47 AM
Views 279
15-02-2021, 06:43 AM
Last Post by Lance79
Views 630
28-04-2020, 11:27 PM
Replies 29
Views 1,456
20-03-2018, 07:15 AM
Views 326
07-03-2018, 05:33 AM
Last Post by bash6673
Replies 24
Views 1,116
13-02-2018, 01:15 AM
Last Post by Phil01
Views 517
16-09-2017, 12:52 AM
Views 425
03-08-2017, 10:33 AM
Views 420
29-07-2017, 10:09 PM
Last Post by TimmyK
