JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension New brakes + fluids
New brakes + fluids
New brakes + fluids
PINGU
13-09-2017, 10:33 AM
Im thinking of getting a set bradied lines aswell as synthetic brake fluid..any ideas of what grade to get..
Also going to change gearbox and diff fluid @ the same time so any recomendations on which to go for
already have new discs + shoes + pads
just wondering on fitting kit for for brake pads + shoes
any help thanks....
[Image: image002-5.jpg]
PINGU
13-09-2017, 10:33 AM #1
any help thanks....
13-09-2017, 10:49 AM
Dot 5.1 for the brake fluid
13-09-2017, 10:49 AM #2
13-09-2017, 10:58 AM
Auto or manual gearbox ?
13-09-2017, 10:58 AM #3
PINGU
13-09-2017, 11:28 AM
manual with lsd
PINGU
13-09-2017, 11:28 AM #4
manual with lsd
13-09-2017, 09:52 PM
According to the official spec sheet, you need the following :
manual gearbox - 1.8L API GL-3 SAE 75W-90
lsd - 1.0L Hypoid gear oil API GL-5 SAE 90
Go for fully synthetic in these. You can actually use the same oil in both (using the higher API GL-5 spec). Something like this stuff. Opie Oils have a big sale on at the moment :wink:
As Moley said, DOT 5.1 is what you want for the brake fluid. Do not use DOT 5, which will not mix with the other types of brake fluid.
13-09-2017, 09:52 PM #5
PINGU
14-09-2017, 11:00 AM
thanks
how much 5.1 will it take
Also any decent places to buy braided brake lines from..
PINGU
14-09-2017, 11:00 AM #6
thanks
15-09-2017, 02:31 AM
I'm not sure how much 5.1 you'll need, but it'll probably take a few litres to flush it all through (until the dirty old stuff starts turning into clear new stuff).
As for braided brake lines, not sure. The Goodridge ones are pretty easy to get hold of, you'll find them on eBay. There are different fittings depending on the model year of your car, I think, something that was debated at length on here a while back. Make sure the seller tells you they're the right ones for your car, in writing, so that if there's a problem you can get a refund/swap.
15-09-2017, 02:31 AM #7
PINGU
15-09-2017, 08:33 AM
ok thanks
one more thing any idea of part number for handbrake shoes fitting kit..
PINGU
15-09-2017, 08:33 AM #8
ok thanks
16-09-2017, 12:52 AM
Handbrake shoes are as follows :
46540-28010 and 46550-28010
46540-18010 and 46590-28010
You need all four of those for a set. These are only the shoes, not the springs, shims or anything else. Ormi will be able to better advise on whether you should be changing anything else.
16-09-2017, 12:52 AM #9
Views 451
28-04-2021, 12:47 AM
Views 280
15-02-2021, 06:43 AM
Last Post by Lance79
Views 631
28-04-2020, 11:27 PM
Replies 34
Views 2,290
31-01-2019, 02:02 AM
Replies 29
Views 1,478
20-03-2018, 07:15 AM
Views 326
07-03-2018, 05:33 AM
Last Post by bash6673
Replies 24
Views 1,133
13-02-2018, 01:15 AM
Last Post by Phil01
Views 425
03-08-2017, 10:33 AM
Views 420
29-07-2017, 10:09 PM
Last Post by TimmyK
