JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Door rubbing strip
Door rubbing strip
Door rubbing strip
Pages (4): 1 2 3 4 Next
09-08-2016, 03:14 AM
Do the door side rubbing strips come colour coded or do they need to be painted?
The one on my right rear door has peeled itself away at the front of the door - I didn't noticed and opened it, it caught the front door which bent it back a bit. If they come prepainted then I'll just get it replaced, but if it needs to be painted I won't bother and just try and stick the end back down.
If the latter, what's the best way to stick it back down again?
09-08-2016, 03:14 AM #1
09-08-2016, 03:17 AM
remove the strip clean all the old tape off(tar and glue or like) the door and the strip and get your self some 3m double sided tape(my side skirts are held on with this and they aint coming off)stick on job done.ask the bandit were he got the stuff he gave me with the skirts?i cant remember.
09-08-2016, 03:17 AM #2
09-08-2016, 05:08 AM
ormi remove the strip clean all the old tape off(tar and glue or like) the door and the strip and get your self some 3m double sided tape(my side skirts are held on with this and they aint coming off)stick on job done.ask the bandit were he got the stuff he gave me with the skirts?i cant remember.
Cheers for both replies mate, I put this on LOC too but no need to reply in both places if you can't be bothered Smile
Awesome, that's good news I was hoping they were.
Only reason I would like to replace is that when I opened the door and bent it back the paint has cracked in that area - the surface isn't broken but the paint is all cracked up (hope that makes sense).
Any ideas how much a strip would cost? And can I remove the old one myself or should I just drop it off at Lexus? Worried that I might pull the paint off the door with it........ :unsure:
09-08-2016, 05:08 AM #3
09-08-2016, 05:47 AM
They come already painted, if you did get a new one.
09-08-2016, 05:47 AM #4
09-08-2016, 10:24 AM
If its bent matey, use a hair dryer to soften it a bit and then use a good VHB double sided tape to stick it back down? the stuff i use will stick brick to brick and is the 3M VHB Tape amazing stuff,
I did the same as Ormi, i fitted all my skirts with it and they never moved untill i had to rip them off, and the tape itself is still on my old car now :lol:
09-08-2016, 10:24 AM #5
09-08-2016, 10:38 PM
Bandit If its bent matey, use a hair dryer to soften it a bit and then use a good VHB double sided tape to stick it back down? the stuff i use will stick brick to brick and is the 3M VHB Tape amazing stuff,
Thanks mate, it's not really that bent, the prob is that the paint has cracked - going to speak to Lexus today to see how much it costs to get a new one and have it fitted and then decide what to do Smile
09-08-2016, 10:38 PM #6
09-08-2016, 10:47 PM
It will be very roughly £50 for one of those in Strathcaron Blue.
09-08-2016, 10:47 PM #7
10-08-2016, 02:57 AM
steviewevie It will be very roughly £50 for one of those in Strathcaron Blue.
Just got off the phone with Lexus, they said £62 for the moulding, and £140 if I wanted them to remove the old one and fit the new one.
That labour cost sounds like a lot, should I just let them do it or is it something I could do myself? What's the best way to remove the old strip?
Another thought, would it be totally out of the question to have a go at sanding it down and respraying the strip? Or would that be unlikely to produce a good quality finish (and end up costing almost the same amount after buying the paint, tape, etc)?
10-08-2016, 02:57 AM #8
10-08-2016, 03:01 AM
Sorry but i would get a body shop to paint this?
10-08-2016, 03:01 AM #9
10-08-2016, 04:30 AM
Lexusboy Sorry but i would get a body shop to paint this?
No point mate, the new ones for £60 come pre-painted, bodyshop would surely charge more than that. I was only asking in terms of a cheap fix using what I've got Blush
10-08-2016, 04:30 AM #10
Views 230
23-01-2021, 07:58 AM
Views 331
30-03-2019, 11:33 AM
Last Post by posty
Views 569
24-11-2018, 04:03 AM
Replies 36
Views 1,821
14-11-2018, 01:40 PM
Last Post by jomo
Views 651
06-04-2018, 10:24 AM
Views 942
22-03-2018, 07:15 AM
Views 683
05-01-2018, 10:57 AM
Views 1,137
28-11-2017, 06:08 AM
Views 429
26-11-2017, 01:06 PM
Views 558
25-09-2017, 12:28 AM
