JapCarForum Car Manufacturers Lexus/Toyota IS200 handbrake adjustment
VVT-Einstein
09-12-2022, 10:54 AM
Hi all, my handbrake is taking about 20 thousand clicks before it starts to do anything... What's the easiest way to tighten / adjust it?
VVT-Einstein
09-12-2022, 10:54 AM #1
09-12-2022, 11:56 AM
On the rear hub is a rubber grommet open that and ur see a dial cog inside adjust that both sides and that should tighten it. It's worth a check of the drum shoes to see if there past it
09-12-2022, 11:56 AM #2
09-12-2022, 11:57 AM
The grommet needs to be at the bottom of the hub around that area and ur see the cog inside
09-12-2022, 11:57 AM #3
09-12-2022, 02:00 PM
I think you flick the cog up to tighten, get it so you can't spin the disc then back off a couple of clicks and job done.
09-12-2022, 02:00 PM #4
09-12-2022, 02:03 PM
Just checked and its down to adjust
09-12-2022, 02:03 PM #5
13-12-2022, 04:47 AM
did you get this done mate ?
13-12-2022, 04:47 AM #6
VVT-Einstein
13-12-2022, 09:10 AM
Thanks for the responses all.
Nah, not had a chance to do it yet, will let you know how I get on:thumbup1:
VVT-Einstein
13-12-2022, 09:10 AM #7
16-12-2022, 01:23 PM
It's really easy dude
16-12-2022, 01:23 PM #8
Views 653
06-01-2024, 08:26 AM
Last Post by bigdave1701
Views 378
09-10-2023, 03:21 PM
Views 425
04-10-2023, 12:38 PM
Last Post by CrocodileHunter
Replies 22
Views 1,429
27-07-2023, 11:45 AM
Replies 52
Views 3,065
14-07-2023, 09:41 PM
Last Post by Mr_Woods
Views 835
25-05-2023, 06:58 AM
Views 464
24-05-2023, 01:50 PM
Last Post by ViperTheLex
Views 699
20-05-2023, 07:02 AM
