JapCarForum Car Manufacturers Lexus/Toyota Lexus is200 fuel pressure & oil pressure
Fire_king
11-03-2023, 01:10 PM
Hi tried searching but couldn't find anything
Lexus is200 1gfe
1. Anyone no what the Stock fuel pressure psi is?
2. What is the oil pressure psi?
Am getting mixed answers on the fuel pressure reading some say 45psi others say 50psi
Thanks in advance
Fire_king
11-03-2023, 01:10 PM #1
Lexus is200 1gfe
Thanks in advance
11-03-2023, 01:46 PM
Anywhere in the range is fine it's not exactly a huge difference.
11-03-2023, 01:46 PM #2
Fire_king
11-03-2023, 10:23 PM
Sparkystav Anywhere in the range is fine it's not exactly a huge difference.
Sorry are you referring to the fuel pressure? So anything between 45psi to 50psi is OK?
Any ideas on the oil pressure?
Fire_king
11-03-2023, 10:23 PM #3
12-03-2023, 11:08 AM
Yes for the fuel pressure,
No idea as oil pressure changes depending on revs, what grade, how warm it is etc
12-03-2023, 11:08 AM #4
Fire_king
12-03-2023, 11:17 AM
Thanks for the input mate. Yea the oil pressure changes I need to no what this is at idle and wat
Am planning to fit a turbo kit and need to no what size oil restrictor I need
Fire_king
12-03-2023, 11:17 AM #5
12-03-2023, 01:14 PM
1mm is fine. That's what I have.
12-03-2023, 01:14 PM #6
Fire_king
20-03-2023, 08:40 AM
Sparkystav 1mm is fine. That's what I have.
Thanks for the reply 1mm am guessing this is for a ball bearing turbo and not a journal bearing?
I need it for a journal bearing 1mm I would have thought is to small
Fire_king
20-03-2023, 08:40 AM #7
is200turbo
20-03-2023, 09:17 AM
I think it's 4mm for journal bearing
is200turbo
20-03-2023, 09:17 AM #8
20-03-2023, 09:54 AM
Ahh right, for a journal I thought you just used the normal oil pressure (I.e. No restriction?).
I could be wrong though.
20-03-2023, 09:54 AM #9
Views 506
06-01-2024, 08:26 AM
Last Post by bigdave1701
Views 73
08-12-2023, 01:42 PM
Last Post by yaser01
Views 327
09-10-2023, 03:21 PM
Views 328
04-10-2023, 12:38 PM
Last Post by CrocodileHunter
Replies 22
Views 1,184
27-07-2023, 11:45 AM
Replies 52
Views 2,523
14-07-2023, 09:41 PM
Last Post by Mr_Woods
Views 738
24-06-2023, 10:57 AM
Views 710
25-05-2023, 06:58 AM
