JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Fuel Filter?
Fuel Filter?
Fuel Filter?
wahidhussain
18-11-2016, 03:25 PM
hi all and best of luck for the new year:thumbup:
i know you all are going to say that no we dont need to change it
but when i Bought the avensis (before the lex) i dont change the fuel filter on that for 2 year and it use to have a poor start (just like the lex) 1 or 3 times a month
than when i changed it was fine after that
so my question is has anyone changed it?
thanks Smile
wahid
wahidhussain
18-11-2016, 03:25 PM #1
thanks Smile
wahid
TM
18-11-2016, 11:21 PM
i changed mine on my GS,found nothing wrong with it but i know that its ok .think every one got his or her own thoughts on this but if u feel u done the milage........change it:Bazza:
TM
18-11-2016, 11:21 PM #2
19-11-2016, 12:17 AM
The fuel filter is in the fuel tank, and you shouldn't have to change it on the IS200. It won't hurt to change it if you want to though.
19-11-2016, 12:17 AM #3
TM
19-11-2016, 12:26 AM
steviewevie The fuel filter is in the fuel tank, and you shouldn't have to change it on the IS200. It won't hurt to change it if you want to though.
Confusedmoke:the GS filter is also in the tank.....and is'nt hard to change.....mine took about 15 min.....:Bazza:
TM
19-11-2016, 12:26 AM #4
19-11-2016, 01:38 AM
ive changed mine, but only cause i uprated the pump.
like has been said its not hard to, but not really needed
19-11-2016, 01:38 AM #5
wahidhussain
20-11-2016, 03:13 PM
sorry for the late reply guys (new year fever)
so which type you would recommend?
thanks
wahid
wahidhussain
20-11-2016, 03:13 PM #6
thanks
wahid
21-11-2016, 05:55 AM
OEM one.
Mine has also been changed, again because of the uprated fuel pump.
21-11-2016, 05:55 AM #7
OEM one.
rob
21-11-2016, 07:40 AM
leave it alone.... you dont need to change it.
rob
21-11-2016, 07:40 AM #8
wahidhussain
22-11-2016, 05:11 PM
hi
rob i want to change it becoz of the poor start i get sometimes
would this one be ok http://cgi.ebay.co.uk/LEXUS-IS200-2-0I-9...5637c99e24
thanks
wahid
wahidhussain
22-11-2016, 05:11 PM #9
hi
thanks
wahid
23-11-2016, 12:35 AM
As many of you have written the fuel filter it is a part of the fuel pump and it is located in the fuel tank. Usually it is not need to be changed. I changed mine only for precaution when i fitted the supercharger. In Greece the fuel is not so clean. You always find some other particles and impurities that might block the filter and this would not be good especially now with the SC where the fuel requirements are critical. Also changing the fuel filter it is a good idea to clean also the fuel tank!
23-11-2016, 12:35 AM #10
Views 287
10-06-2020, 05:52 AM
Views 275
19-03-2020, 06:22 AM
Last Post by ozzie b
Views 345
08-09-2019, 02:59 AM
Last Post by MKT222
Views 1,035
27-02-2019, 11:54 AM
Last Post by Barry
Replies 27
Views 1,643
20-08-2018, 03:32 AM
Last Post by sprinter2012
Replies 56
Views 3,630
18-04-2018, 10:32 AM
Last Post by karlp
Views 352
18-06-2017, 08:52 AM
Views 502
09-05-2017, 08:21 AM
Views 803
22-01-2017, 02:20 AM
Last Post by Mikey
