JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza fuel consumption problem
Mikey
21-01-2017, 08:17 AM
I have a problem im getting through £50 worth of fuel in 160 miles it used to be a lot more, when i tried to give it i hit the valve lift just over 4k rpm it stinks like bad eggs thats whats pointed me to the cat any help please
Mikey
21-01-2017, 08:17 AM #1
kam05
21-01-2017, 08:20 AM
Not sure what the problem is, but I get about 240 miles out of £50 of juice (mix of dual carriageway and town driving).
Is the engine management light on?
kam05
21-01-2017, 08:20 AM #2
21-01-2017, 08:23 AM
not sure but dont sound good i would get it looked at asap
21-01-2017, 08:23 AM #3
21-01-2017, 08:36 AM
Could be many things, best thing to do is have a garage look at it.
21-01-2017, 08:36 AM #4
rig-pig
21-01-2017, 08:40 AM
bad egg smell points to a *(edited by moderator)* knackered cat m8 get a garage to check it on the gas tester and perfect excuse to get rid of the pre-cats
Edited 05-03-2010, 12:34 PM by steviewevie.
[Image: Photo003-1-1.jpg]
Craig
time served car mechanic
now a rig monkey
rig-pig
21-01-2017, 08:40 AM #5
Craig
now a rig monkey
21-01-2017, 08:41 AM
The rotten-egg smell comes from a clogged or plugged catalytic converter or a very rich fuel mixture. Which can also give you really crappy mpg? Hows it driving mate? does it pull ok through the gears? Could be a collapsed pre-cat or the main cat given up?
21-01-2017, 08:41 AM #6
21-01-2017, 10:26 AM
No warning lights on the dash ? I wonder if one of the sensors is acting up. Sounds like it's over-fuelling if you're using way too much fuel, which often can be down to a sensor problem.
21-01-2017, 10:26 AM #7
edeath
21-01-2017, 11:02 PM
Mikey is200/s13 when i tried to give it i hit the valve lift just over 4k rpm it stinks like bad eggs thats whats pointed me to the cat any help please
Sorry to be pedantic but its the variable inlet manifold opening at 4.2k - IS200 has not got lift adjutment (VTEC / VVTL-I.)
Along with the cat and sensor suggestions can be the engine running too hot (but you would notice on the temp gauge) or a dodgy fuel pressure regulator.
edeath
21-01-2017, 11:02 PM #8
21-01-2017, 11:35 PM
Yep, what Ed said ^^^^^
The VVT-i is active across the rev range, and doesn't suddenly kick in like VTEC or similar, but the inlet manifold does suddenly open up (it has a valve inside it to change its shape internally), and this is what you can sometimes feel/hear at about 4k-ish rpm.
You could get the fuelling checked on a rolling road.
21-01-2017, 11:35 PM #9
Mikey
22-01-2017, 12:44 AM
no dash lights and driving fine so its check list time
cat/pre cats
cat sensor
Mikey
22-01-2017, 12:44 AM #10
cat/pre cats
cat sensor
Views 207
25-12-2020, 10:57 AM
Views 696
16-09-2020, 01:57 AM
Last Post by danny1377
Views 288
10-06-2020, 05:52 AM
Views 278
19-03-2020, 06:22 AM
Last Post by ozzie b
Views 428
04-01-2020, 11:29 AM
Last Post by Dinho
Views 344
01-11-2019, 02:01 PM
Last Post by rigga
Views 472
10-09-2019, 11:55 AM
Last Post by ormi
Views 345
08-09-2019, 02:59 AM
Last Post by MKT222
Views 425
20-07-2019, 10:04 AM
Last Post by pauls_is200
