JapCarForum General Discussions The JCF Lounge PC problem
PC problem
PC problem
26-01-2017, 03:15 AM
Sorry guys, but I have another PC problem. One of our computers developed a problem at the weekend, got a blue screen (just a blank blue screen) and it wouldn't respond to anything. Switched it off manually, and then when I switched it back on it wouldn't boot into windows, it would start up, and just keep rebooting over and over.
Assuming it was dead, I thought I'd do a system restore. However before starting it (no idea why I did this) but unplugged all the peripherals, and restarted the computer, and this time it booted into windows and looked fine. At this point I didn't think the USB disconnections had any relevance.
Anyway, as it was back up and running, I thought I'd still restore it, but back up all the data first. I couldn't get it to sync with my external hard drive over the network, so plugged it in via USB and as soon as I plugged it in it started rebooting again, and did the same where it did it over and over - but then as soon as I unplugged it it booted back into windows fine!
So restored the PC after this and everything seemed fine. However this morning while still updating bits and bobs, I was downloading IE8 and then suddenly mid-download it restarted again. Allowed it to boot up again, and this time before I even tried it again it restarted again. Just switched it off and left it, need to take a look when I get home tonight.
Does anyone have any idea what might be wrong? Is this a software or hardware problem? And do the USB connections have anything to do with it or was that coincidental?
26-01-2017, 03:15 AM #1
26-01-2017, 03:25 AM
So it always does this when the USB hard drive is plugged in ? Even after the restore ? How about if you try the hard drive in a different USB port ?
26-01-2017, 03:25 AM #2
26-01-2017, 03:43 AM
steviewevie So it always does this when the USB hard drive is plugged in ? Even after the restore ? How about if you try the hard drive in a different USB port ?
No haven't tried the hard drive now, the hard drive stuff was before the restore.
All that's plugged in at the mo is a webcam, printer and wireless mouse. Although it's not doing the thing where it boots over and over, this is fully booting into windows, but then once you start doing anything it reboots. It might happen after 5 mins, maybe after 20, but there's clearly a problem.
26-01-2017, 03:43 AM #3
26-01-2017, 03:44 AM
off topic.....I just got blue screened at work, said that hardware mailfunctioned.....luckily had just saved my work, manaully restarted and seems ok
26-01-2017, 03:44 AM #4
26-01-2017, 03:51 AM
Power supply problems can cause rebooting/blue screen issues like that. Could be the power supply on its way out. Or some sort of glitch on your power line, i.e. problems with the supply coming into your computer.
26-01-2017, 03:51 AM #5
26-01-2017, 03:59 AM
steviewevie Power supply problems can cause rebooting/blue screen issues like that. Could be the power supply on its way out. Or some sort of glitch on your power line, i.e. problems with the supply coming into your computer.
Ahhhhh thats ok as long as its not my dual head graphics card on its way out!!
26-01-2017, 03:59 AM #6
26-01-2017, 04:01 AM
Hmmm, I'm going to try unplugging all the USBs again and see if the problem persists. Maybe it's a power management issue related to the USB ports? And would that be a problem with the power supply or the motherboard?
26-01-2017, 04:01 AM #7
Anees
26-01-2017, 08:08 AM
Check all your USB port - one might be damaged and shorting out; I've had that a few times in the past causing random reboots etc. Big Grin
[Image: clubbanner.gif]
Anees
26-01-2017, 08:08 AM #8
26-01-2017, 08:18 AM
Anees Check all your USB port - one might be damaged and shorting out; I've had that a few times in the past causing random reboots etc. Big Grin
I actually tried the hard drive in every USB port, and they all made it reboot......I'll have to open it up and see if there's anything obviously wrong on the board. Otherwise I guess it still could be a dying hard drive or something as it is quite old now.
26-01-2017, 08:18 AM #9
26-01-2017, 08:21 AM
This is the high reliability of windows for you.
26-01-2017, 08:21 AM #10
Replies 22
Views 993
06-09-2018, 12:18 PM
Replies 25
Views 939
04-04-2018, 02:11 AM
Views 376
08-04-2017, 08:39 AM
Views 583
25-03-2017, 09:15 AM
Last Post by Fry-Up
Views 589
20-03-2017, 03:49 AM
Last Post by lexynik
Replies 34
Views 1,367
25-01-2017, 02:10 PM
Views 385
05-11-2016, 02:20 AM
Last Post by Anees
Views 382
11-10-2016, 06:02 AM
Last Post by Dan_Turism0
Views 806
06-07-2016, 10:24 PM
Views 297
29-06-2016, 06:27 AM
Last Post by Y2KANJAR
