JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Knock sensor problem??
Pages (4): 1 2 3 4 Next
21-06-2017, 02:27 AM
On the way back form Rabsters yesterday my car started to drop power now and again, then about 15 miles from home the engine management light came on, just read the code and its come up with P0330 Knock Sensor #2 — Circuit Malfunction (Bank #2)
Any ideas on what could be the cause for this? dodgy knock sensor or could it be something else?
Not sure if the timing has been adjusted when it had the turbo fitted, been running fine since i got it, but did use normal unleaded fuel yesterday for over 330 miles? where i've been using super unleaded since i got it? not sure if it has anything to do with it?
Any help would be appreciated :thumbup1:
Edited 02-08-2010, 12:04 PM by Bandit.
21-06-2017, 02:27 AM #1
21-06-2017, 02:34 AM
No idea mate, but you may want to change your title of the thread Wink
I will wait to see if my dad comes on, he may know.
21-06-2017, 02:34 AM #2
Fozzy
21-06-2017, 02:38 AM
Knock sensors dont tend to go faulty, i would think its more likely to be a wiring issue. Id check around for and dodgy connections. There has been a lot of fiddling around in the bay so its possible something isnt connected properly. Id also check in the ecu box to make sure everything is connected properly in there
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
21-06-2017, 02:38 AM #3
21-06-2017, 02:44 AM
Thanks Pete, will have a look mate, i might of caught something when i was cleaning the engine bay on Saturday morning and not noticed it?
it was fine before so hopefully something simple? :thumbup1:
21-06-2017, 02:44 AM #4
TM
21-06-2017, 02:52 AM
check for burn't wiring from the turbo,when it had it onConfusedmoke:
u'll sort it mate:Bazza:
TM
21-06-2017, 02:52 AM #5
21-06-2017, 10:41 AM
Been out and had a play with the car, checked all the wiring and seems ok, there are a few bits that have melted plastic coverings,
so have tidied them up? been for a spin in it and all seems ok so far??
The engine management light has stayed off, so not sure if its cured or not so will just keep an eye on it for a bit? :thumbup1:
21-06-2017, 10:41 AM #6
banky
21-06-2017, 02:00 PM
hope car is ok m8 or only needs little fixin
banky
21-06-2017, 02:00 PM #7
21-06-2017, 10:36 PM
banky hope car is ok m8 or only needs little fixin
Cheers matey, it seems ok and its boosting as it should again :thumbup:
21-06-2017, 10:36 PM #8
25-06-2017, 02:33 PM
Ok the light came on again today, only did 3 miles and wouldn't pull away very well?? once it got going it wasn't too bad, but had no power when trying to accelerate :Chair:
Any more ideas on what could be the cause?? :Shooting::Shooting:
25-06-2017, 02:33 PM #9
Phil01
25-06-2017, 03:34 PM
Chris try reusing super fuel again, as you know a knock sensor detects detonation. Inside the sensor is piezoelectric crystals that vibrate when detonation occurs, this creates a voltage output in relation to the severity of the knock, then the ESA map retards the timing until detonation stops. may just be a case of poor fuel that is causing your problem, as you did state it has always run on super before the fault occurred. Eliminate that first mate.
ESA=Electronic Spark Advance.
Phil01
25-06-2017, 03:34 PM #10
Views 2,289
02-11-2022, 10:55 AM
Views 184
25-12-2020, 10:57 AM
Views 591
16-09-2020, 01:57 AM
Last Post by danny1377
Views 250
10-06-2020, 05:52 AM
Views 363
04-01-2020, 11:29 AM
Last Post by Dinho
Views 293
01-11-2019, 02:01 PM
Last Post by rigga
Views 323
23-10-2019, 06:59 AM
Last Post by reganlives
Views 508
12-09-2019, 02:13 PM
Last Post by IanH
Views 417
10-09-2019, 11:55 AM
Last Post by ormi
Views 390
20-07-2019, 10:04 AM
Last Post by pauls_is200
