fault code p0105
fault code p0105
it says it the vacum sensor fault. any idea why this still comes back. seems it only comes when it's cold. have checked all the lines and they are good
Normally related to the FCD mate
but i have a piggyback ecu. i clear the code and after a day or 2 it comes back.
A bad connection or similar if it's only happening when cold perhaps ?
If soldered connections, check them if any look dull and not shiny apply a little heat from an iron and ad more solder, it could be a "dry" joint, these give problems and are hard to locate.
well i've been home sick for 2 days now and not used the car. when i parked it up a few days ago the engine manage light was on and the trc was blinking as normal. so today when i went to the shops with the family i started up and left the garage and the looked down to check if the car was going into limp mode as soon as i hit 3000 rmp and no lights and no blinking trc. ???? this just makes me ever more unsure whats going on. temp outside was -4
Its hitting the fuel cut.
Has the output of the emanage been clamped at the right voltage?
Has it got an uprated MAP sensor ?
it's got a extra maf sensor but dont think the oem one has been changes
