JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza HID fault help please lol
daz
13-12-2017, 12:53 PM
Hi, my hiss have developed a fault.
They are TRD items, I believe have been fitted by previous owner.
They turn on, lamps flash on and then go off.
Any thoughts? I have checked the wiring and all seems ok, although there is a box inline with the ballast box, not sure what this is.
Where do I start? Surely if bulbs have blown they won't light at all? Just odd that both have stopped working?
Cheers
daz
13-12-2017, 12:53 PM #1
Cheers
13-12-2017, 12:55 PM
get some pics up mate possibly a vid of the lamps when they try to strike
the ballast is there to ignite the lamps if the lamps have both died then the ballast will fail strike so you get a spark but not proper light or the ballasts could be gone...
13-12-2017, 12:55 PM #2
daz
13-12-2017, 12:59 PM
Ok will try post a vid, just wierd in my experience for them to both go....
Cheers
daz
13-12-2017, 12:59 PM #3
Cheers
13-12-2017, 01:02 PM
it sounds like a power issue...
13-12-2017, 01:02 PM #4
daz
13-12-2017, 01:06 PM
Rabster it sounds like a power issue...
I agree, how would I test this? Where do I start lol, I may remove the kit and try a temp install on a battery
daz
13-12-2017, 01:06 PM #5
14-12-2017, 02:05 AM
Some kits have a separate starter, that's probably what the second box plugged into the ballast is.
Bulbs are probably fine, it's most likely something is up with the ballasts.
14-12-2017, 02:05 AM #6
mplavery
14-12-2017, 05:03 AM
I had the same thing but only one was not working and it was the Ballast box which was blown.The price of one Ballast box was almost the same as the kit so i brought a new kit in the end.
Because you have both blown it would be very bad luck that both boxes are gone....
2nd BEST IN SHOW (JAE 2011)
3rd BEST MODIFIED (JAE 2011)
[/COLOR]
[/COLOR]
mplavery
14-12-2017, 05:03 AM #7
[/COLOR]
[/COLOR]
Views 257
01-11-2019, 02:01 PM
Last Post by rigga
Views 709
25-10-2017, 04:25 AM
Views 745
16-11-2016, 10:56 AM
Last Post by spikes
Replies 18
Views 940
10-09-2016, 07:58 AM
Last Post by Sam B
