JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza How to remove headlight help urgent!
Pages (3): 1 2 3 Next
karlp
11-03-2019, 07:44 AM
Yo guys attempting the detango and spray headlights today but I'm having trouble removing and finding the 2nd nut to take the headlight out, ive removed the top nut but can't get to the 2nd nut as it's behind a metal frame? Is this the correct nut to remove?
karlp
11-03-2019, 07:44 AM #1
11-03-2019, 07:45 AM
The two nuts should be accessable from the arch behind the liner.
turn the wheel or take it off so you can have a right good look
11-03-2019, 07:45 AM #2
karlp
11-03-2019, 07:49 AM
I've taken the top nut off but How do you remove the lower nut??? Can't even get to it?
[Image: 4954b41f.jpg]
karlp
11-03-2019, 07:49 AM #3
rob
11-03-2019, 07:54 AM
long extension and a universal joint worked for me
rob
11-03-2019, 07:54 AM #4
karlp
11-03-2019, 07:59 AM
I've got a shifter and a 10mm spanner Sad
karlp
11-03-2019, 07:59 AM #5
karlp
11-03-2019, 09:05 AM
[Image: f5f4afbd.jpg]
Just picked up this from a mate how shall I get to the nut?
karlp
11-03-2019, 09:05 AM #6
11-03-2019, 09:43 AM
Well, I did it using very similar kit bud - with skinned knuckles...
A case of bending the arch liner far enough out to get in with the ratchet. I managed to get the extension bar onto the nut first then pushed the ratchet onto the end to undo it...
Real PITA job though... Smile
11-03-2019, 09:43 AM #7
karlp
11-03-2019, 09:44 AM
Okay nuts off how do you release the black headlight leveler box from the headlight??
karlp
11-03-2019, 09:44 AM #8
Oh, and don't worry, the driver's side is much easier for some reason Big Grin
11-03-2019, 09:44 AM #9
11-03-2019, 09:45 AM
You don't, you unclip the white plug from it and the whole headlight assembly comes out..
Mind and take out the bulbs as well before you yank out the light...
11-03-2019, 09:45 AM #10
Views 802
12-12-2024, 07:55 PM
Views 693
31-10-2020, 07:50 PM
Last Post by rigga
Views 1,340
27-08-2020, 07:55 PM
Replies 25
Views 2,154
07-08-2020, 07:00 PM
Last Post by Chris0121
Views 1,441
07-08-2020, 03:11 PM
Views 483
08-05-2020, 06:28 PM
Last Post by jasons
Views 1,019
07-03-2020, 04:36 AM
Last Post by nimrodmk3
Views 933
21-12-2019, 06:25 PM
Last Post by is300_dino
Views 1,828
20-07-2019, 11:53 AM
Last Post by speedfreek
