another is200 project
Anyone have any ideas on lambdas on decated exhausts im getting the fault code 4020 I think an it says catalytic below efficiency so think av got them to far into the exhaust wondered if I needed to weld on an addapter to bring it out the pipe more if that would fix it any ideas would help
Also bought some universal lambda sensor would seem lexus are far to upper class to use them
You need an O2 simulator instead of the last lamba to fool the ecu to thinking its working properly.
I did make and sell them for a while. But I'm not sure I've got the right bits still.
If you don't mind waiting a week or so i can make one up for you.
well it replaces the standard rear sensor and send the ecu a signal that its all ok
Sparkystav well it replaces the standard rear sensor and send the ecu a signal that its all ok
