JapCarForum Cars, Cars, Cars! Project Cars My IS200 so far
My IS200 so far
My IS200 so far
Chris0121
07-01-2020, 11:09 AM
Can you not flat them with a bit of sandpaper and water then buff them up mine did it slightly when I done my lights but flatted them down and buffed them back up and they came out alright
Chris0121
07-01-2020, 11:09 AM #11
Mr-cth
08-01-2020, 12:48 PM
naw no chance of tht mate unfort even the side light hole melted shut sorted another one 2day so shud b here in couple of days and i can get it sorted, cheers mate ive only got lik 2 and half threads on the front wheels so hopefully they shud sort it.
Mr-cth
08-01-2020, 12:48 PM #12
Mr-cth
22-01-2020, 10:39 AM
so got some new wheel studs in
[Image: IMG-20130227-00060_zps541b7708.jpg]
good bit longer, almost too long because im using tuner nuts so mite not beable to get key in with nuts fully screwed in, but before hit tht problem had an absolute handiling tryna get them on got some nuts tht matched the threads and tryed to screw the studs into the hub but just cud not get them to come through cuz was just using a ratchet and socket but the hub was free so was very hard to tighten them, ended up just having to pop old studs back in which was easy enugh to do which makes me think mayb the new studs wernt rite altho think it would hav been alot easier with an impact wrench but instead of gettin one of those or takin it to a garage decided on a new plan, was just catching the very edge of the brake caliper holder so decided just to grind the edge off this is it before
[Image: IMG-20130304-00065_zps1694386f.jpg]
only took off a very small amount
[Image: IMG-20130304-00066_zpsba4d35c2.jpg]
problem sorted now got a gd 3 or 4 turns on wheel stud, if only hadnt wasted money on the new studs but ey wat can u do
Mr-cth
22-01-2020, 10:39 AM #13
22-01-2020, 11:20 AM
The studs will be right, I found the best way to get them in is by packing them with washers between hub and the nut, they do pull on though
22-01-2020, 11:20 AM #14
Mr-cth
22-01-2020, 01:08 PM
had a big nut over the top and a washer, even giv it a spray of grease too and was still near enugh impossible to tighten it any more think i need to get a breaker bar or something but problem is sorted now anyway and only had to grind it back by lik 2mm or 3mm in the corner and its sweet now with out the spacers, does anyone kno if an HID kit like this one would pass the MOT
http://www.ebay.co.uk/itm/Xenon-HID-Conv...4d0361a664
Mr-cth
22-01-2020, 01:08 PM #15
27-01-2020, 06:25 AM
i never had any issues with HID's for my MOT mate
27-01-2020, 06:25 AM #16
27-01-2020, 06:44 AM
Same here never had an issue
27-01-2020, 06:44 AM #17
Mr-cth
26-02-2020, 10:30 AM
alrite guys been busy got a fair few updates on the car, first of all got aload of the wee smd lights and did me dash lights
[Image: IMG-20130308-00067_zps3579ebff.jpg]
looks so much better and was so easy to do, relly needa change heater controls as well now, also got some blue wheel nuts for me alloys,
[Image: Coleraine-20130408-00082_zpsac64057b.jpg]
look well like and they r so much better than the crappy tuner nuts that came with the car altho had to get breaker bar just to keep in the car as its 19mm socket, also decided to switch number plates round to square plates, rear was easy just take old one off and pop new ones on and done
[Image: Coleraine-20130408-00080_zps124b1322.jpg]
front was abit more of a challenge as once i took the old ones off and got rid of the wee black surround left with 2 big holes either side of the bumper
[Image: Coleraine-20130407-00076_zps24a29044.jpg]
so added a wee bit of filler and got it all sanded down
[Image: Coleraine-20130407-00077_zps913c4956.jpg]
then painted it all up and poped it back on also poped a wee tow strap in the front
[Image: Coleraine-20130408-00079_zpsa15a9cc6.jpg]
looks ten times better in my opinion so this is how car looks now,
[Image: Coleraine-20130408-00083_zpsbf34f9ce.jpg]
obviously still need new front light but not to bad, all comments welcome
Mr-cth
26-02-2020, 10:30 AM #18
26-02-2020, 10:42 AM
Like the dash (white is best colour)
Don't like rear square plate but the front is spot on great work
Keep hunting for a new light mate
26-02-2020, 10:42 AM #19
26-02-2020, 12:41 PM
Nice little mods mate!
26-02-2020, 12:41 PM #20
Views 6,196
09-04-2024, 01:09 AM
Views 1,573
06-04-2024, 05:57 PM
Views 111,826
25-03-2024, 02:10 AM
Views 10,840
23-03-2024, 03:45 PM
Views 23,833
18-02-2024, 11:42 PM
Views 77,551
08-02-2024, 01:53 AM
Views 511
18-12-2023, 02:55 AM
Views 1,671
08-10-2023, 03:59 AM
Views 3,529
04-10-2023, 03:52 PM
Views 2,286
17-05-2023, 11:25 AM
