JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza fault code p0105
fault code p0105
fault code p0105
24-10-2017, 02:38 AM
You still need the OEM MAP sensor in there for the OEM ECU to use.
But as Stav says, it sounds like you're hitting the fuel cut. The OEM MAP sensor might be seeing too much boost, and then going into limp mode. But the e-Manage should be preventing this by clamping the MAP sensor voltage that is being sent to the OEM ECU - that's all setup in the mapping and it sounds like there might be a problem, as Stav said.
24-10-2017, 02:38 AM #11
24-10-2017, 02:43 AM
will be going back to him soon as need to finish getting 320 out of it. now that i've changed the clutch he can finish it
24-10-2017, 02:43 AM #12
24-10-2017, 03:18 AM
The EManage should be using the aftermarket MAP sensor to calculate the fuel needed etc.
But it also needs to send a clamping voltage out to the standard one to stop it hitting fuel cut. It may be that its doing it, but the extra cold weather has just tipped it over the edge
24-10-2017, 03:18 AM #13
25-10-2017, 03:43 AM
jay_russell will be going back to him soon as need to finish getting 320 out of it. now that i've changed the clutch he can finish it
How you finding the clutch? Its the same one Stevie has and I also had it.
25-10-2017, 03:43 AM #14
25-10-2017, 03:55 AM
the fensport one? thats what i fitted and yer it's ok. fitted a short shift so cant tell the difference with it but it's good. want the summer here so i can drift a bit round the back of the hotel.
25-10-2017, 03:55 AM #15
25-10-2017, 04:04 AM
Great for drifting that place!!
All the locals use it also, but in Volvos - you need to show them up!!
25-10-2017, 04:04 AM #16
25-10-2017, 04:25 AM
i hope to but need the carpark first. have 5 set of tyres to burn up so just need the snow to go
25-10-2017, 04:25 AM #17
Views 258
01-11-2019, 02:01 PM
Last Post by rigga
Views 701
24-07-2019, 09:41 AM
Views 340
05-09-2018, 12:38 AM
Views 665
29-04-2018, 09:14 AM
Views 464
14-12-2017, 05:03 AM
Last Post by mplavery
Views 746
16-11-2016, 10:56 AM
Last Post by spikes
Replies 18
Views 940
10-09-2016, 07:58 AM
Last Post by Sam B
