JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Help identify the brakes
16-03-2018, 08:29 AM
easier doing it here than on fb mate :lol:
R32 GTR (Non V-Spec) Sumitomo caliper
Master Cylinder diam (mm) - 25.4
Front Caliper Piston(diam x qty) - 40.4 ×4
Front rotors (diam x thk) - 296×32
Rear Caliper Piston(diam x qty) - 38.18×2
Rear Rotors (diam x thk) - 297×18
R32 GTR V-Spec / R33 / 34 GTR with Brembos
Master Cylinder diam (mm) - 26.9 568.32mm²
Front Caliper Piston(diam x qty) - (44+3Cool×2 ... leading pistons smaller then trailing 5309.29mm²
Front rotors (diam x thk) - 324×30
Rear Caliper Piston(diam x qty) - 40×2 2513.27mm² ratio FR = 2.1125
Rear Rotors (diam x thk) - 300×22
Total area - 7822.56 Brake to master ratio - 13.76
Will keep searching mate and see what else i can find :thumbup1:
16-03-2018, 08:29 AM #11
16-03-2018, 08:36 AM
my piston dimensions are
28mm deep
40mm wide at base
37mm wide at top
16-03-2018, 08:36 AM #12
28mm deep
40mm wide at base
37mm wide at top
16-03-2018, 09:01 AM
lol there worn out at the top then :lol: will keep searching mate :lol:
16-03-2018, 09:01 AM #13
16-03-2018, 09:18 AM
right according to all the images i have found
they are almost certainly r32gts-t callipers
16-03-2018, 09:18 AM #14
16-03-2018, 10:02 AM
so ...
R32 GTST
Master Cylinder diam (mm) - 25.4 area 506.71mm^2
Front Caliper Piston(diam x qty) - 40.4 ?4 = 5127.58mm^2
Front rotors (diam x thk) - 280?30
Rear Caliper Piston(diam x qty) - 38.18?2 = 2289.78mm^2 ratio FR = 2.239
Rear Rotors (diam x thk) - 297?18
total 7417.36 brake to master ratio 14.63
Which would mean its the 2.0ltr model from 1989-1994
16-03-2018, 10:02 AM #15
so ...
R32 GTST
16-03-2018, 10:41 AM
thats what its kinda looking like guess the only way is to find a recon kit an giv it a go ....
might try nissan directly in the morning see if they have any....
16-03-2018, 10:41 AM #16
16-03-2018, 11:14 AM
ok here are the pics that have been stripped using nitromours and are smooth ish now
so hopefully when painted they will look goodConfusedcared:
[Image: 5bd59c64.jpg]
[Image: 3b191d90.jpg]
[Image: d719b3b7.jpg]
[Image: d48906f6.jpg]
what are your thoughts ...
16-03-2018, 11:14 AM #17
16-03-2018, 11:33 AM
the current setup is still lexus standard just with mintex pads on the front standard lexus on the rear....
this will allow the upgrade and hopefully stop well they were on Dave Reeds car
16-03-2018, 11:33 AM #18
16-03-2018, 11:47 AM
yeah as in the mini monster nah no changes on the setup yet still toying with the ideas....
16-03-2018, 11:47 AM #19
17-03-2018, 12:19 AM
ok have just ordered 2 seal kits one per side and a grand total including delivery of 47.98
just hope the poxy things fit now lol
17-03-2018, 12:19 AM #20
Views 529
28-04-2021, 12:47 AM
Views 306
15-02-2021, 06:43 AM
Last Post by Lance79
Views 739
28-04-2020, 11:27 PM
Replies 34
Views 2,466
31-01-2019, 02:02 AM
Views 355
07-03-2018, 05:33 AM
Last Post by bash6673
Replies 24
Views 1,264
13-02-2018, 01:15 AM
Last Post by Phil01
Views 589
16-09-2017, 12:52 AM
Views 462
03-08-2017, 10:33 AM
Views 458
29-07-2017, 10:09 PM
Last Post by TimmyK
