JapCarForum Cars, Cars, Cars! General Car Maintenance just bought is300,quick question.
23-11-2019, 04:56 AM
ive been thinking, as you've just brought it, does anyone think there could be any reason for the original owner/garage to take the dash apart and take any warning lights out to cover any hidden faults, like 02 sensors if its been sitting around for a while and they've not reconneted the plug back in properly to the cluster, so occasionally the power for that block dips out as its not plugged in fully? id start by taking the clocks apart look at the bulbs see if they are all still in, reconenect all the plugs so they sit in properly and hope that fixes it, if you do find any bulbs missing obd it and get back to the person you brought it from, good luck hope you get it sorted soon and welcome to the 300 club
23-11-2019, 04:56 AM #11
IanS200
23-11-2019, 06:16 AM
is300_dino ive been thinking, as you've just brought it, does anyone think there could be any reason for the original owner/garage to take the dash apart and take any warning lights out to cover any hidden faults, like 02 sensors if its been sitting around for a while and they've not reconneted the plug back in properly to the cluster, so occasionally the power for that block dips out as its not plugged in fully? id start by taking the clocks apart look at the bulbs see if they are all still in, reconenect all the plugs so they sit in properly and hope that fixes it, if you do find any bulbs missing obd it and get back to the person you brought it from, good luck hope you get it sorted soon and welcome to the 300 club
Thanks for your reply and welcome, will be doing the above today, could well be what you said as theres old wiring for amps ect all over the place, just been disconnected and pushed under carpets.fingers crossed.
IanS200
23-11-2019, 06:16 AM #12
24-11-2019, 04:40 AM
Good idea, and yes if there's a bit of a wiring mess definitely a possibility. Is it a regular flash or an intermittent one like a loose connection?
24-11-2019, 04:40 AM #13
IanS200
24-11-2019, 06:22 AM
parthiban Good idea, and yes if there's a bit of a wiring mess definitely a possibility. Is it a regular flash or an intermittent one like a loose connection?
flashes regulary, reading manual says if its a gearbox fault PWR light should flash but it doesnt ?????
IanS200
24-11-2019, 06:22 AM #14
24-11-2019, 05:37 PM
IanS200 flashes regulary, reading manual says if its a gearbox fault PWR light should flash but it doesnt ?????
More reason to think it's a wiring problem although if it's a regular flash I'm not really sure.
Best to ring your dealer and see if there is any situation in which those lights will flash - if there isn't then it's most likely a wiring problem.
24-11-2019, 05:37 PM #15
IanS200
29-11-2019, 11:57 AM
cured itself, gearbox went poof, gone back to an is200 again..:mellow:
IanS200
29-11-2019, 11:57 AM #16
29-11-2019, 12:29 PM
Sorry to hear it mate, what a shame did you get ur IS200 back or get another one if so what is it and what plans, plus in no bad way means you can attend the show now
29-11-2019, 12:29 PM #17
IanS200
29-11-2019, 02:32 PM
Lexuspat Sorry to hear it mate, what a shame did you get ur IS200 back or get another one if so what is it and what plans, plus in no bad way means you can attend the show now
Got another is200, 90k fsh ,private plate ect, going to pinch a few bits from 300 and then sell whats left of it.
Got an op end of march on knee and then 6 wks in pot, so if all goes well will def be attending.
IanS200
29-11-2019, 02:32 PM #18
IanS200
29-11-2019, 03:59 PM
Marsdendean Did the garage / person not give you your money back? Shame to hear went pop, never heard it before . . . .
deal done through the dreaded swaps site, it was faultless on drive back (140 miles). then gearbox indicator prnd ect started flashing mpg guage stuck on 40mpg.. checked oil and topped it up as nearly empty, didnt overfill, took it for a drive and a pipe blew on gearbox covered all under car in oil,now jumps when all gears selected and engine light on.
IanS200
29-11-2019, 03:59 PM #19
29-11-2019, 04:10 PM
Like I said Ian sorry to hear it but glad you have a lexus and can't wait to see what you can get done before the end of May
29-11-2019, 04:10 PM #20
Views 1,441
10-12-2021, 07:03 PM
Last Post by jeffrosie
Views 1,215
10-05-2021, 04:35 PM
Last Post by Fry-Up
Views 1,983
18-09-2019, 08:27 PM
Last Post by VINNY867
Views 3,057
24-08-2019, 06:27 AM
Views 1,943
29-07-2019, 08:24 AM
Views 3,236
19-07-2019, 04:44 PM
Last Post by sprinter2012
Views 3,215
19-06-2019, 01:13 PM
Last Post by jimxms
Replies 27
Views 5,125
19-03-2019, 10:18 AM
Last Post by jimxms
Replies 24
Views 3,792
28-03-2018, 04:25 AM
