JapCarForum Cars, Cars, Cars! Project Cars Stix's IS200
Stix's IS200
Stix's IS200
Pages (45): Previous 127 28 29 30 3145 Next
Chris0121
08-12-2019, 06:46 AM
Doesn't stav have a meth kit for sale or has he sold it
Chris0121
08-12-2019, 06:46 AM #281
08-12-2019, 07:07 AM
Chris0121 Doesn't stav have a meth kit for sale or has he sold it
Swapped it for a nitrous kit mate.
08-12-2019, 07:07 AM #282
I think if you're building from scratch a water to air intercooler is a better solution than meth injection, plus you don't have to worry about running out.
Probably isn't much in it in terms of weight either, after you've added the meth injection bottle and gubbins. If you've got an intercooler air to air set up anyway, it's probably simpler just to add meth injection afterwards.
Depends if you design the build from scratch or add on as you go I suppose.
08-12-2019, 07:07 AM #283
Chris0121
08-12-2019, 08:02 AM
Sparkystav Swapped it for a nitrous kit mate.
Good man can't wait to see that fitted
Chris0121
08-12-2019, 08:02 AM #284
S
08-12-2019, 12:00 PM
The bulk of the weight is the liquid I think.
I'd just like to say something:
dear man at the council who decided to use plastic "safety" bollards instead of concrete ...I could ******* kiss you.
I've just hit one at about 10mph and there is 0 damage not even scratches in the paint! Big Grin
S
08-12-2019, 12:00 PM #285
08-12-2019, 12:14 PM
el_bandido I think if you're building from scratch a water to air intercooler is a better solution than meth injection, plus you don't have to worry about running out.
I'd disagree, a simple tank, some line, a pump, and a jet?
Compared to a custom design and fabricated charge cooler, re routing pipework, a pump, a tank, and then pipework for the coolant?
The WI can be added to any setup in a couple of hours, charge coolers a full r&d then a days work at least.
08-12-2019, 12:14 PM #286
08-12-2019, 12:16 PM
The major issue with water/meth injection is that to take full advantage of it, you have to map using it, and then you're screwed when you run out. Unless your ECU is smart enough to have a float in the tank and switch maps when the level is low, you'll kill your engine if you're mapped for meth injection and you don't have any.
08-12-2019, 12:16 PM #287
08-12-2019, 05:05 PM
Sparkystav I'd disagree, a simple tank, some line, a pump, and a jet?
yeah but mapping meth/water injection is a complete ball ache if you run out surely?
Edit: toxo beat me to it!
Edited 19-01-2013, 02:39 AM by el_bandido.
08-12-2019, 05:05 PM #288
08-12-2019, 10:53 PM
It can be. Depends how aggressive your going. But a simple float switch isn't a hard thing to wire in.
08-12-2019, 10:53 PM #289
09-12-2019, 12:00 AM
i have a switch on my meth kit so you can choose when to use it and its then safe if you run out
09-12-2019, 12:00 AM #290
 3 Guest(s)
 3 Guest(s)
Views 5,130
09-04-2024, 01:09 AM
Views 1,291
06-04-2024, 05:57 PM
Views 102,880
25-03-2024, 02:10 AM
Views 9,095
23-03-2024, 03:45 PM
Views 20,393
18-02-2024, 11:42 PM
Views 68,316
08-02-2024, 01:53 AM
Views 405
18-12-2023, 02:55 AM
Views 1,490
08-10-2023, 03:59 AM
Views 3,139
04-10-2023, 03:52 PM
Views 1,953
17-05-2023, 11:25 AM
