JapCarForum Cars, Cars, Cars! Project Cars My Lexus RS200 Turbo Build
Pages (3): Previous 1 2 3
Lexus RS200T
19-06-2022, 03:11 AM
Hi Ladies and Gents. I know need your guys help.
My Tachometer on the Lexus read now 2/3 of the value due to I changed the engine from a 6cyl to a 4cyl.
How do I go about to fix it on the tachometer or anyplace else. I cant change it on my new ECU.
Thank you
Lexus RS200T
19-06-2022, 03:11 AM #21
Thank you
beamstezza
19-06-2022, 07:45 AM
Just curious was the car a lexus is200 or altezza as200?
beamstezza
19-06-2022, 07:45 AM #22
19-06-2022, 08:16 AM
There is adjusters out there mate but they aren't cheap.
19-06-2022, 08:16 AM #23
Tosh21
19-06-2022, 08:56 AM
Simplest fix would be an altezza cluster but they can be hard to find and expensive .There's one on tezzaworld for 150 euros
Tosh21
19-06-2022, 08:56 AM #24
Lexus RS200T
19-06-2022, 05:59 PM
The car is a Lexus IS200.
I saw there is a thing on the market called tachometer adapter. Will see if i can get hold of one.
Lexus RS200T
19-06-2022, 05:59 PM #25
Lexus RS200T
22-06-2022, 12:34 AM
I installed a new 320Lph fuel pump so that I don't have any starvation on fuel, the fuel pump holder had to be modified for a return line. Installed a 10mm fuel line and the original fuel line I used as the return back to the tank. Reusable FTF fuel filter was installed and a FTF fuel pressure regulator. All the fuel lines in the car is AN6 fuel lines and all the fitting is FTF blue and red anodized fittings.
I installed a oil cooler in front of the car with a Aero oil thermostat. I relocated the oil filter as well because with the engine sitting horizontal it was point to the road.
After all of that the wiring started. With the Lexus you can not remove the original ECU as the whole cars electronics works from it or is tied into it same way or another. So I had to cut from the original ecu what I was not going to use and wire some of the back to my new ecu that is running the engine, it was a timely affair but I got it working and that was a great.
.jpg
.jpg
.jpg
.jpg
.jpg
Lexus RS200T
22-06-2022, 12:34 AM #26
.jpg
.jpg
.jpg
.jpg
.jpg
Lexus RS200T
29-07-2022, 06:33 PM
Hi guys
Sorry for the long delay. The car was at the dyno two weeks ago. It made 205kw and 309nm torque on the wheels on 1 bar boost. Feels like a new machine and is really strong. Will take it back in 1500km so that they can take up the boost. First need to run it in further and change to full synthetic oil.
Lexus RS200T
29-07-2022, 06:33 PM #27
Hi guys
Tosh21
30-07-2022, 11:52 AM
Nice, some decent power there! Are you running the engine without the plastic cover on the front? I ran mine with just the top cover off and a stone go in there and shreded the timing belt. I got very lucky to spot it before it broke!
Tosh21
30-07-2022, 11:52 AM #28
Lexus RS200T
30-07-2022, 06:45 PM
No I run it with all the plastic covers on to protect the the timing belt and gears.
Lexus RS200T
30-07-2022, 06:45 PM #29
Views 102,896
25-03-2024, 02:10 AM
Views 20,419
18-02-2024, 11:42 PM
Views 68,539
08-02-2024, 01:53 AM
Views 918
31-10-2023, 10:05 PM
Views 1,491
08-10-2023, 03:59 AM
Views 6,022
06-10-2023, 02:58 AM
Views 3,144
04-10-2023, 03:52 PM
Replies 76
Views 2,819
30-09-2023, 01:24 AM
Last Post by RichS11
Views 22,148
10-09-2023, 07:50 PM
Views 1,956
17-05-2023, 11:25 AM
