Dave's IS200 Sport
Dave's IS200 Sport
Pages (45): Previous 1 2 3 4 545 Next
05-04-2017, 10:35 AM
As noted earlier, I need to change the brake discs and pads on the car (and get a couple of tyres) - what do you guys think of these brakes?
Discs
Pads
Appreciate the opinions of those *far* more knowledgeable than me... which is everyone, including Oli, guests to the board and the Yahoo! Slurp Spider...
05-04-2017, 10:35 AM #21
Discs
Pads
05-04-2017, 01:16 PM
go for them mate they are the ones that the girl from my work put on and they feel really good........
05-04-2017, 01:16 PM #22
05-04-2017, 01:29 PM
Cheers mate, will get them ordered this week Smile
05-04-2017, 01:29 PM #23
Fozzy
05-04-2017, 01:57 PM
The pads are fine, nothing wrong with mintex. Probably nothing wrong with the discs, but you could get them cheaper from here
http://www.crnperformance.co.uk/store/in...&x=10&y=14
I bought a set of their discs fro my MR2. They offer a service to zinc plate the discs for about 20 quid or so. You can have them finished in yellow/gold or silver. That stops them rusting up.
Im impressed with mine so far
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
05-04-2017, 01:57 PM #24
05-04-2017, 02:49 PM
Sounds interesting, Hurricane Smile
Think I'd have to go with silver for that though, think gold a touch too ostentatious for me Smile Yours look good though! tempting...
05-04-2017, 02:49 PM #25
micromarc
03-05-2017, 11:54 AM
If your still lookin for a guy to do your paint work can highly recomend my mate. Ask ormi if your not sure, it's the guy doin his mates rx8 Wink
micromarc
03-05-2017, 11:54 AM #26
Ally
05-05-2017, 09:42 PM
edeath I agree with steve that ARBs and lowering springs can make the ride quite harsh at times. Especially on our current potholey roads. Though must say on smooth roads it great Smile
Effectively the ARBs double your spring rates on one sided movement - so having stiffened the springs anyway its going to be quite hard riding. IE - ARBs + Double stiff springs would equal 4 x stiffness rather than the 2 x with just arbs or just 2 x springs. Rather simplistic explanation but hopefully works.
I've already got the TTE lowering springs, and about a month ago i listened to all the hype and got the TTE arbs. Not got them fitted yet though. Do you reckon if i get them fitted on the softest of the 2 settings they should be ok? I usually drive on uneven country roads to get to work so that may be a problemConfusedad:. Typical...........
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
05-05-2017, 09:42 PM #27
Fozzy
06-05-2017, 12:20 AM
The ARB's shouldnt make the ride too mush harsher, the will just limit the amount of body roll. Of course this will affect the chassis a little over bumps by limiting the amount of travel on the wheel in bump by spreading it across the axle.
Id try it and see what suits you best, its not a big job to swap between the settings
Fozzy
06-05-2017, 12:20 AM #28
06-05-2017, 02:12 PM
Mabozza Ritchie I've already got the TTE lowering springs, and about a month ago i listened to all the hype and got the TTE arbs. Not got them fitted yet though. Do you reckon if i get them fitted on the softest of the 2 settings they should be ok? I usually drive on uneven country roads to get to work so that may be a problemConfusedad:. Typical...........
their is no soft or hard setting the holes are their so you can have the anti roll bar link straight as poss,if they are at an angle they can bend.....
think about it people...what diff would it make having a roll bar higher or lower coz thats all the holes do.......they are in a bush and the bar moves inside the bush so moving the link will not make them stiffer..
06-05-2017, 02:12 PM #29
Ally
06-05-2017, 09:12 PM
Thanks chaps. I'll get them fitted and stick to smooth roads :thumbup1:.
Ally
06-05-2017, 09:12 PM #30
Views 5,161
09-04-2024, 01:09 AM
Views 1,309
06-04-2024, 05:57 PM
Views 103,345
25-03-2024, 02:10 AM
Views 9,145
23-03-2024, 03:45 PM
Views 20,467
18-02-2024, 11:42 PM
Views 69,056
08-02-2024, 01:53 AM
Views 410
18-12-2023, 02:55 AM
Views 1,496
08-10-2023, 03:59 AM
Views 3,150
04-10-2023, 03:52 PM
Views 1,961
17-05-2023, 11:25 AM
