JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes - more problems
Pages (5): Previous 1 2 3 4 5
27-09-2017, 12:43 PM
#41
Are your discs warped? My wobble problem was because of warped discs, the confusing part being why new sets of discs kept warping within a few thousand miles. Hence the warped flanges were discovered.
If your discs aren't warped though that does point to potentially a different problem, might be worth a trip to WIM for the boys to strip everything down and see what's there?
27-09-2017, 12:43 PM #41
dodgydave
27-09-2017, 12:49 PM
#42
No I don't think the discs are warped. I'm going to see if I can borrow a dial gauge from work for the week end and see if I can check everything out, discs and flanges.
The funny thing is like Dean I've only had this problem since I painted my callipers. It could be down to that pin/ bush as I found this pin quite tight then and cleaned it up a lubricated it.
dodgydave
27-09-2017, 12:49 PM #42
27-09-2017, 01:34 PM
#43
dodgydave That's brilliant.
Any idea of price?? Not an arm and a leg are they??
I'd say less than £20 for the lot mate
27-09-2017, 01:34 PM #43
28-09-2017, 03:00 AM
#44
Does sound like it might be a sticky caliper or something then, hopefully it's a simple fix Smile
28-09-2017, 03:00 AM #44
dodgydave
28-09-2017, 10:38 AM
#45
Phoned Lexus/Toyota today to get prices. for reference they are:-
47715-22070 Bottom Pin - £6.09 each
47715-30060 Top Pin - £8.09 each
47769-50010 Sliding Bush - £3.42 each
all plus the dreaded VAT.
I've order 2 x Bottom pins and 2 x Bushes. I will be picking up on Saturday so hopefully if the weather is OK at the week end I'll fit them and we will see if that makes any difference. If it doesn't make any difference it won't be wasted, you can see from the picture one needed changing anyway.
I'll keep you updated.
dodgydave
28-09-2017, 10:38 AM #45
28-09-2017, 11:48 PM
#46
Marsdendean So does this solve a sticking caliper, or just help things move a bit more??
That will depend on exactly why your caliper is sticking. If it's sticking because of these bushes, then yes, it will. If it's sticking because of pitted pistons, then no, it won't.
28-09-2017, 11:48 PM #46
Views 538
29-08-2021, 09:59 AM
Views 295
06-01-2020, 07:01 PM
Views 713
27-06-2019, 10:25 AM
Last Post by Matt_C
Views 455
16-03-2019, 10:07 PM
Last Post by lex2oos
Views 1,185
04-11-2018, 05:02 AM
Last Post by Stoney
Views 836
01-06-2018, 10:52 AM
Views 525
15-02-2018, 02:31 PM
Last Post by LEX11S
Views 686
18-07-2017, 04:20 AM
Last Post by Rolex
Views 440
23-06-2017, 06:40 AM
Last Post by jomo
Views 515
27-04-2017, 12:56 PM
Last Post by Namking998
