JapCarForum Cars, Cars, Cars! Project Cars Stix's IS200
Stix's IS200
Stix's IS200
Pages (45): Previous 16 7 8 9 1045 Next
09-06-2020, 05:52 AM
#71
el_bandido I still don't understand how adding bigger disks on to the same sized callipers will make even an ounce of difference. The contact patch would be identical wouldn't it?
The further the contact point is from the axis of rotation, the stronger the braking force will be, regardless of contact area.
Think about trying to undo a really stubborn bolt, if you use a longer breaker bar, you can undo it with the same force by just moving the application of the force further away.
The force (torque) is directly proportional to the increase in size (radius.) t = F x R
FirebirdPhil Heat will be lost from the disk quicker and it is heat that causes poor breaking.
And this^^^
Edited 21-07-2012, 09:40 AM by sprinter2012.
09-06-2020, 05:52 AM #71
And this^^^
S
09-06-2020, 08:26 AM
#72
Bigger is always better regardless!!
S
09-06-2020, 08:26 AM #72
S
24-06-2020, 01:27 PM
#73
[youtube]yGiloyNtfa4[/youtube]
Edited 05-08-2012, 05:18 PM by S.
S
24-06-2020, 01:27 PM #73
24-06-2020, 01:43 PM
#74
That's exactly what I was going to do with my setup to keep it all hidden and stealthy, good work!
24-06-2020, 01:43 PM #74
S
24-06-2020, 02:14 PM
#75
I did it for a couple of reasons,
the first is how trick/swish it is
The second is I'm not particularly keen on pillar mounts and I couldn't think of anywhere else that didn't look bodged/"forced" if you know what I mean?
S
24-06-2020, 02:14 PM #75
S
04-07-2020, 03:27 PM
#76
Car is broke!
wont run! it starts, runs for 1 second and then dies.
Ive checked everything, ive even put a new fuel pump in for good measure!
had the AA bloke out, he couldnt work out what was wrong and he said i had checked most of the things he would check!
so ive had it dragged to a local auto electrician:
[Image: carfrwend2.jpg]
[Image: carfrwend.jpg]
S
04-07-2020, 03:27 PM #76
Car is broke!
04-07-2020, 04:53 PM
#77
gutted you didnt sort it,
id suggest removing the emanage, bit by bit.
take off the fuel connections, try it, then ignition, try it, etc till its all off
04-07-2020, 04:53 PM #77
S
05-07-2020, 05:47 PM
#78
that was the plan Stav but the situation is a little complicated so i just did as my parents suggested to prevent them asking too many questions!
The electrician has until wednesday and if it isnt running then im having it dragged home and ill do the fault finding myself.
I did just win this on ebay though:
[Image: HKScooler.jpg]
[Image: HKScooler2.jpg]
S
05-07-2020, 05:47 PM #78
05-07-2020, 06:18 PM
#79
Now that is nice! Is it genuine?
05-07-2020, 06:18 PM #79
S
05-07-2020, 06:22 PM
#80
Ive honestly no idea, I hope so!
It was only £80 either way!
S
05-07-2020, 06:22 PM #80
Views 14,954
Views 4,098
Views 177,162
Views 23,202
Views 48,427
Views 145,132
Views 1,357
Views 3,923
Views 6,810
Views 5,048
