JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension supra 4 pot brakes
supra 4 pot brakes
supra 4 pot brakes
20-07-2017, 08:25 PM
hi there,
thinking to buy the 4 pot supra brakes but i need 15mm spacers for the calipers to fit and i was wondering would that stick the wheel to far out?
any idea?
thanks
20-07-2017, 08:25 PM #1
hi there,
any idea?
thanks
20-07-2017, 08:42 PM
Think Stav has the 15mm spacers on his mate but they might be bigger and his seem ok?
If you do get a set go for the hub centric spacers as there a lot safer to use? LIKE THESE? Big Grin
20-07-2017, 08:42 PM #2
20-07-2017, 08:44 PM
thanks bandit. i really want the brakes but dont want the wheel to come too far out.
20-07-2017, 08:44 PM #3
21-07-2017, 04:02 AM
You should be able to measure where you wheels are at the moment. They'll come out 15mm with those 15mm spacers. I'd be really suprised if that was too far, but you can put a tape measure there and see.
21-07-2017, 04:02 AM #4
21-07-2017, 07:53 AM
was going to do that last night but was too wet out there so thought i will just ask you
21-07-2017, 07:53 AM #5
21-07-2017, 08:08 AM
Lol depends if someone has the same wheels as you ! I haven't.
21-07-2017, 08:08 AM #6
21-07-2017, 10:42 AM
I have 15mm spacers and no they dont stick out too far.
i would say though, do not get the spacers bandits linked to. I had some like that and the key to get the nuts off is **** and the nuts seized to the bolt as well, had to angle grind one off in the end!
get a set of H&R ones with longer bolts. their the best IMHO.
though get hubcentric ones like has already been said
21-07-2017, 10:42 AM #7
21-07-2017, 01:48 PM
right thanks stav will look into h and r ones
hope i win these calipers
21-07-2017, 01:48 PM #8
Views 593
28-04-2022, 06:35 AM
Views 325
15-02-2022, 12:32 PM
Last Post by Lance79
Views 809
29-04-2021, 05:16 AM
Replies 34
Views 2,575
31-01-2020, 07:51 AM
Replies 29
Views 1,746
20-03-2019, 01:04 PM
Views 382
07-03-2019, 11:22 AM
Last Post by bash6673
Replies 24
Views 1,361
13-02-2019, 07:03 AM
Last Post by Phil01
Views 660
16-09-2018, 06:41 AM
Views 493
03-08-2018, 04:22 PM
