JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza throttle jammed open?
Pages (3): 1 2 3 Next
25-08-2016, 03:59 AM
Hi guys bit of a weird one this,
as I was driving home on lunch upon accelerating my pedal stuck firmly to the floor thus making the engine bounce off the red-line, I managed to get it unstuck by squeezing my foot under the pedal and forcing it back to a normal position.
Any ideas why this has happend or how to resolve? Also anyone had similar problems before?
25-08-2016, 03:59 AM #1
25-08-2016, 04:09 AM
The mat didn't get in the way, did it ? That's the usual cause of a stuck throttle.
LGB7Y
Edited 05-01-2010, 02:00 PM by steviewevie.
25-08-2016, 04:09 AM #2
LGB7Y
kam05
25-08-2016, 04:23 AM
What Stevie said.
kam05
25-08-2016, 04:23 AM #3
What Stevie said.
25-08-2016, 04:25 AM
nope definately not mate Sad
25-08-2016, 04:25 AM #4
25-08-2016, 04:27 AM
Dan when you turn on the car with your key does it go straight up to red line?
25-08-2016, 04:27 AM #5
25-08-2016, 04:29 AM
nope, this happend as I was driving along, although now you mention it I do remember a few months ago starting the car and the throttle going to redline
25-08-2016, 04:29 AM #6
25-08-2016, 04:32 AM
If you look at the throttle cable is there any breaking of the cable check from the peddal
Thought to the throttle housing.
25-08-2016, 04:32 AM #7
25-08-2016, 04:59 AM
will have to have a check at 5pm after work
25-08-2016, 04:59 AM #8
25-08-2016, 05:02 AM
Dan can you not get out before as around 5 it is getting dark and you might not see whats wrong.
25-08-2016, 05:02 AM #9
25-08-2016, 05:41 AM
If you sit there with the car off and just jam the throttle pedal to the floor, does it still get stuck? Or was it just a one-off?
25-08-2016, 05:41 AM #10
Views 784
07-06-2019, 02:01 AM
Last Post by S
Views 568
15-05-2019, 05:06 PM
Last Post by Mr Reman
Views 447
22-12-2018, 01:54 AM
Last Post by Talisker
Views 2,364
30-08-2018, 02:37 PM
Views 506
27-04-2018, 01:31 AM
Last Post by is300_dino
Views 1,136
28-11-2017, 06:08 AM
Views 490
10-10-2017, 08:57 AM
Views 261
09-10-2017, 05:41 AM
Views 551
30-07-2017, 01:30 AM
Last Post by Hogan22a
Views 850
17-06-2017, 10:53 AM
