JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Dash lights
Dash lights
Dash lights
garyskisplym
14-03-2017, 10:27 AM
When the car is turned on two clicks (so radio on and everything wlse but no engine) there is a orange light that comes up on the dash but as soon as you turn key again it goes out.
It has a couple lines coming off it. What is this for??
garyskisplym
14-03-2017, 10:27 AM #1
14-03-2017, 10:30 AM
what does it look like mate, engine, oil can, battery?
EDIT: if it is a car with 2 lines out the back it means traction control
14-03-2017, 10:30 AM #2
garyskisplym
14-03-2017, 10:39 AM
not traction.
Dont really know how to explain it.
Its in the same area as traction light.
The has 4 or 5 lines out the back, will go and check in a min and post what it exactly looks like.
garyskisplym
14-03-2017, 10:39 AM #3
not traction.
14-03-2017, 10:51 AM
get a pic mate Smile
14-03-2017, 10:51 AM #4
garyskisplym
14-03-2017, 10:59 AM
Cant get a pic as camera rubbish on my photo.
It is the the right of the battary symbol. The picture of of car and has 6 lines coming out of the rear with 3 on right 3 on left.
Heres a pic of the location (indicated by red circle)
[Image: dash.jpg]
Edited 25-04-2010, 08:37 PM by garyskisplym.
garyskisplym
14-03-2017, 10:59 AM #5
[Image: dash.jpg]
14-03-2017, 11:01 AM
is the pic bad quality, still may be able to see what it is
EDIT: ah the lines coming out of the back. This is a brake failure warning light.
It tells if one of your brake lights are out. or if you have just put leds in you need a load resistor mate.
14-03-2017, 11:01 AM #6
Andy-R.
Is it the one with the car and a couple of liines behind it? if so it's for the rear light failure warning basically to tell you if a bulbs gone or if there's a problem with your rear lights.
[Image: Lf9Nl.jpg]
Andy-R.
14-03-2017, 11:01 AM #7
[Image: Lf9Nl.jpg]
garyskisplym
14-03-2017, 11:10 AM
Ok that iswhat i thought.
Just found it weird the other day i unpluged a bulb and it did not light up.
Or does it not light up if no bulb in holder??
garyskisplym
14-03-2017, 11:10 AM #8
14-03-2017, 11:12 AM
you need to put the handbrake down and depress the brake.
14-03-2017, 11:12 AM #9
14-03-2017, 11:16 AM
That's for the rear side light failure, if you have a brake light out the handbrake light to the left will stay lit if a brake light bulbs gone..
14-03-2017, 11:16 AM #10
Views 154
07-10-2020, 01:46 AM
Last Post by Stoney
Views 699
05-08-2019, 12:42 PM
Last Post by mattlaw
Views 347
28-06-2019, 10:43 AM
Last Post by purplewitch
Views 1,369
18-06-2019, 11:52 AM
Views 398
05-05-2019, 11:07 AM
Last Post by is200iain
Views 379
24-01-2019, 07:04 AM
Last Post by is300_dino
Views 1,029
28-11-2018, 10:22 AM
Last Post by sprinter2012
