JapCarForum Car Manufacturers Lexus/Toyota Replacing Cabin Air Filter on Lexus SC430
21-04-2018, 05:27 AM
You first need a Phillips head screwdriver remove the phillip head from right side of the glove compartment door and pull the lifter mechanism from the post. This will gives you access -- you need to get the door out of the way by releasing it.
Once into the compartment and turn the plastic button only a quarter turn and then pull the button into the glove compartment. alittle force on this to get it to pop it out -- it is plastic and bends easily, Lower the drawer and pull toward you.
Take hold of the outer edges, then pull the compartment containing the filter toward you.
ReInstall the new filter Pay attention to airflow direction.
Replace filter drawer and push in until it snaps then continue to put back as you Took apart.
You can also look at your manual that gives a few picture's:thumbup1:
21-04-2018, 05:27 AM #1
Views 230
07-12-2024, 07:31 PM
Last Post by yaser01
Views 1,002
10-05-2024, 06:55 PM
Views 892
30-04-2024, 06:05 AM
Views 855
08-04-2024, 05:08 AM
Last Post by Niliano
Views 1,378
19-03-2024, 03:43 PM
Replies 46
Views 4,522
17-03-2024, 06:55 AM
Last Post by P.Lindblom
Views 485
24-12-2023, 03:19 PM
Last Post by rock on
Views 1,258
04-09-2023, 09:46 AM
Last Post by phaebo
