JapCarForum Cars, Cars, Cars! Project Cars 1JZ Powered IS200!!
1JZ Powered IS200!!
1JZ Powered IS200!!
Pages (14): Previous 110 11 12 13 14
Sam B
28-03-2018, 10:16 AM
Rabster looking good mate so what doesnt work with the ecu not connected ?
as far as im aware, the only thing that doesnt work is engine related, everything else seems to work fine line instrument cluster etc. reading about i found topics saying that the standard ecu was a multiplex and controlled alot of things in the car and really couldnt be left out. but everything needed still works so no need for it atm but im sure the tuner will be the final decider.
[Image: DWSIG2.jpg]
Sam B
28-03-2018, 10:16 AM #131
[Image: DWSIG2.jpg]
28-03-2018, 01:28 PM
As far as I can work out (this is from dismantling an LS not an IS) the multiplex system is mainly passive. It's there for the various smaller ECUs to report errors back to the main ECU etc, but they're not a requirement. The LS even has an MPX ECU in each door :lol:
Does your aircon work?
28-03-2018, 01:28 PM #132
Sam B
29-03-2018, 12:32 PM
toxo As far as I can work out (this is from dismantling an LS not an IS) the multiplex system is mainly passive. It's there for the various smaller ECUs to report errors back to the main ECU etc, but they're not a requirement. The LS even has an MPX ECU in each door :lol:
thats intresting to know, I have removed the aircon from the 1jz.
[Image: DWSIG2.jpg]
Sam B
29-03-2018, 12:32 PM #133
[Image: DWSIG2.jpg]
bazza1981
06-08-2018, 06:54 AM
hi sam
i doing the same conversion as you have done soon i need some advice on mounts can you help
bazza1981
06-08-2018, 06:54 AM #134
hi sam
bazza1981
06-08-2018, 06:55 AM
good build
bazza1981
06-08-2018, 06:55 AM #135
good build
Ashs14a
16-05-2019, 07:27 AM
How did this build thread stop here.......!!!!!! I'm on the edge of my seat waiting for the results.
Awesome build mate
Ashs14a
16-05-2019, 07:27 AM #136
Awesome build mate
 7 Guest(s)
 7 Guest(s)
Views 5,450
09-04-2024, 01:09 AM
Views 1,410
06-04-2024, 05:57 PM
Views 106,104
25-03-2024, 02:10 AM
Views 9,667
23-03-2024, 03:45 PM
Views 21,316
18-02-2024, 11:42 PM
Views 71,361
08-02-2024, 01:53 AM
Views 452
18-12-2023, 02:55 AM
Views 1,572
08-10-2023, 03:59 AM
Views 3,306
04-10-2023, 03:52 PM
Views 2,126
17-05-2023, 11:25 AM
