JapCarForum Cars, Cars, Cars! Project Cars Home built charged is200!!
21-07-2021, 12:47 PM
Unless you have money to burn Tim I agree with Pat, extremist was very brave and stepped out on his own but he said if he blows up his car no big deal, he'll fit a new engine .. That's a huge risk for most people when there are countless other threads of successful implementations to go with .... And let's not forget poor extremist has disconnected his cos 'it was vibrating do badly it almost ripped the cradle off'
21-07-2021, 12:47 PM #11
21-07-2021, 01:26 PM
The security screws are a five pointed star with security hole you can buy them on eBay,
Alternatively grind a slot in the screw and screw it out with a screwdriver
21-07-2021, 01:26 PM #12
mattlaw
21-07-2021, 02:32 PM
Or drill them out if you round them off :blushing:
mattlaw
21-07-2021, 02:32 PM #13
tim996
21-07-2021, 08:23 PM
Ok bypass valve it is then, can you still run the ssqv with the bypass or is it a case of scrap ssqv completely?? Also how much are the mini valve new?
tim996
21-07-2021, 08:23 PM #14
reganlives
27-07-2021, 01:48 AM
Have you test fitted the pulley yet mate as I found one recently and noticed how they're the same size
reganlives
27-07-2021, 01:48 AM #15
27-07-2021, 04:29 AM
U can run both but then the ssqv judt becomes noise
27-07-2021, 04:29 AM #16
tim996
27-07-2021, 11:23 PM
Have test fitted pulley and had it running on tick over with charger, its the right diameter just 1 rib wider than the 5pk 790 belt im using, had to drill out the holes slightly bigger but thats it, mini bypass valve ordered, and front mount fitted so nearly there now.
tim996
27-07-2021, 11:23 PM #17
reganlives
27-07-2021, 11:38 PM
Perfect mate!!! Nice one!
reganlives
27-07-2021, 11:38 PM #18
Views 6,087
09-04-2024, 01:09 AM
Views 1,568
06-04-2024, 05:57 PM
Views 111,764
25-03-2024, 02:10 AM
Views 10,646
23-03-2024, 03:45 PM
Views 23,320
18-02-2024, 11:42 PM
Views 77,470
08-02-2024, 01:53 AM
Views 502
18-12-2023, 02:55 AM
Views 1,667
08-10-2023, 03:59 AM
Views 3,471
04-10-2023, 03:52 PM
Views 2,269
17-05-2023, 11:25 AM
