JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza throttle jammed open?
25-08-2016, 05:46 AM
I would hardly say it happens often nor would I say it's a one off as it did jam open upon just starting the car the other month and then today for some reason whilst driving it jammed open.
25-08-2016, 05:46 AM #11
25-08-2016, 07:39 AM
Have you actually got your head down there and had a look?
25-08-2016, 07:39 AM #12
25-08-2016, 07:56 AM
yep, all seems fine although a bit dry which could be the cause.
One thing I did notice (apologies for the poor terminology here) but when pulling the throttle wheel the car revs fine then the small pulley to the left rattles as the engine is reducing revs, it sounds asthough a screw/bolt is loose or that kind of sound.
Unfortunately without taking the casing off it's hard to properly see
25-08-2016, 07:56 AM #13
25-08-2016, 08:25 AM
Mine rattled the same Dan and probably still does, was like it all the time i owned the car? But never had any problems with the throttle body :confused:
25-08-2016, 08:25 AM #14
25-08-2016, 08:35 AM
hmm, maybe it was just very dry then hopefully the WD40 has done the trick it did see a lot more free after giving it a spray Smile
25-08-2016, 08:35 AM #15
24-12-2016, 09:56 AM
in light of recent discovery by Toyota think i've got just cause to ring them and ask? :p
24-12-2016, 09:56 AM #16
24-12-2016, 10:00 AM
Somehow I don't think they will see the funny side.............:ohmy:
24-12-2016, 10:00 AM #17
24-12-2016, 10:26 AM
Dan_Turism0 in light of recent discovery by Toyota think i've got just cause to ring them and ask? :p
I think those phone lines might be a bit busy ! :ohmy:
24-12-2016, 10:26 AM #18
24-12-2016, 10:28 AM
you couldnt of timed it better if you tryed dan, dont think toyolex will be happy hearing another case but i think you should tell them just in case mate! mine got stuck about a year ago but like others have said slipped mat was the cause but even then i had to prise the peddle off the floor luckily its not reoccured.
24-12-2016, 10:28 AM #19
24-12-2016, 10:41 AM
Sad mine defo isn't mat related might be worth giving them a shout, although I can see them turning round saying my car's too old (2000X)
24-12-2016, 10:41 AM #20
 4 Guest(s)
 4 Guest(s)
Views 636
07-06-2019, 02:01 AM
Last Post by S
Views 502
15-05-2019, 05:06 PM
Last Post by Mr Reman
Views 390
22-12-2018, 01:54 AM
Last Post by Talisker
Views 2,087
30-08-2018, 02:37 PM
Views 423
27-04-2018, 01:31 AM
Last Post by is300_dino
Views 423
10-10-2017, 08:57 AM
Views 239
09-10-2017, 05:41 AM
Views 483
30-07-2017, 01:30 AM
Last Post by Hogan22a
Views 745
17-06-2017, 10:53 AM
