JapCarForum Cars, Cars, Cars! Project Cars Yet Another IS200 to be Turbo'd
Pages (7): Previous 1 2 3 4 57 Next
john wan
10-12-2021, 05:16 AM
Do you have a standalone or what are you running as im still with standard ecu
john wan
10-12-2021, 05:16 AM #21
10-12-2021, 12:42 PM
Is there any reason that you can't just fit a bigger one way fuel line?
10-12-2021, 12:42 PM #22
10-12-2021, 12:49 PM
You could do. But with boost you could do with a rising pressure as you go into boost this is easiest achieved using an aftermarket fpr
10-12-2021, 12:49 PM #23
10-12-2021, 03:03 PM
And an after market fpr requires a return line? What is the actual purpose of the fuel return line? Is it just the fuel equivalent of a bov that recirculates excess back into the tank?
10-12-2021, 03:03 PM #24
jeffrosie
10-12-2021, 04:30 PM
I'm not going external fuel pressure regulator.
And as I'm staying low boost due to std internals, the std fueling should be ok.
jeffrosie
10-12-2021, 04:30 PM #25
10-12-2021, 04:36 PM
i'm running a emanage blue and i joined the lambda together. and as for low boost you will still need a fuel return line and a bigger pump for there is a chance when you gas it you will be running lean and thats not good. better to go the right way first time. or your just waiting for the problems to come.
10-12-2021, 04:36 PM #26
10-12-2021, 04:43 PM
el_bandido And an after market fpr requires a return line? What is the actual purpose of the fuel return line? Is it just the fuel equivalent of a bov that recirculates excess back into the tank?
Yes mate. It basically controls the pressure from the pump through the rail to itself.
The standard one is in the tank, so in theory you could fit it there I suppose.
10-12-2021, 04:43 PM #27
jeffrosie
10-12-2021, 06:54 PM
Looks like I need to add more things to my shopping list.
What about a fpr from a Celica turbo or MR2 turbo? The std ones must be rising rate.
What pipe do you'll use to make the fuel return line from and where can it be reconnected to the tank for the return?
jeffrosie
10-12-2021, 06:54 PM #28
10-12-2021, 07:17 PM
If you look in my thread there's a link to my.is about the return line and all the bits you need mate
10-12-2021, 07:17 PM #29
john wan
11-12-2021, 02:45 AM
If you have a look at my threads as well I did a how to with pickys basically yo fit onto the bolt at the end of the fuel rail an then drill a hole and fitting into top of the sender part of the tank sounds bad but isnt
john wan
11-12-2021, 02:45 AM #30
Views 7,291
Views 1,899
Views 120,307
Views 12,233
Views 27,090
Views 86,295
Views 604
Views 1,907
Views 3,844
Views 2,607
