1JZ Powered IS200!!
1JZ Powered IS200!!
Moley You must know a thing or two about engines then :lol:
And well done to the willing friends :thumbup1:
D6NGR.. Carn't wait till this is done going to be a "MONSTER"
Top work mate,
as for the ECU, ive said it before but you cant fault the Link G4 for what it can do and esp the price
I was thinking about going AEM with a 2j-1j patch harness, but its about double the cost and all import only. so tax man will add to it.
haltech is another one but no PnP, Just looked at the G4 and is a very good price and quite easily avalible too. done a search of them on the 1jz and found quite alot of handy info and steps on wirring it up!
any recomended places to buy it from stav?
Thor are the UK suppliers i believe mate, and as an offical OJC trader could be a nice little discount.
might give them a ring on monday, are you running the G4 storm? im guessing if you are you are running it on batch fire? cylinder 1+4 2+5 3+6? because it seems there is only four outputs for ign and inj
Sam B might give them a ring on monday, are you running the G4 storm? im guessing if you are you are running it on batch fire? cylinder 1+4 2+5 3+6? because it seems there is only four outputs for ign and inj
Update
Finally got my injectors from japan after a month of waiting! They are Sard 800CC drop ins.
So i went about fitting them today, i also connected up the fuel lines etc and test fitted the inlet on. bit tight to fit it onto the block in the car but makes it on.
Looking good :thumbup1:
Not long now hopefully!!
Looks awesome mate, annoying the injectors took so long
