Bandit's Supercharged IS200 take 2 :-)
looking great Chris, it will soon be better than it was before.
Keep up the hard work matey .
Do i see a wire tuck coming here??
DaveEdin Looking good Chris, gonna shine up the rocker that's come off?
Thought i'd crack on and fit the Koni shocks/springs and the TTE arbs today, fronts fitted fine and look good with no problems...
Then started to do the rear, took one side off and removed the shock and arb drop link? found one of the bolts holding the arb in place had broken so was held on by one bolt :ohmy: fitted the shock and went and jacked up the other side, undid the shock then looked for the drop link bolt?? MMMmmm now where would that be????????:confused::confused:
Yes you guessed it, there's NO BOLT and NO DROP LINK attached to the ARB?? hock:
hock:
To say i wasn't impressed is an understatement :cursing::cursing::mad::mad::cursing::cursing:
So now i have to drill the broken bolt out, and now get a drop link and lower bolt so i can finish the job :cursing::cursing::cursing::mad:
Yeh there **** mate, the allen key head usually rounds off and the nut jams tight due to the dirt round them? i usually clean the threads off and give them a good soak before trying to remove them? the other 3 were fine and came off no problem? but the 4th didn't exist :Chair:
