JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Intermittent HID problem
Pages (4): 1 2 3 4 Next
07-12-2016, 02:09 AM
Since getting back from hols, my RH headlamp has been working on and off. When I start the car it doesn't work, but then after 15-20 mins of driving it comes on and then stays on.
Is this likely to be a problem with the headlamp or elsewhere? I was just wondering whether a weak battery could cause this? All was fine before I went on holiday, but then the car was sitting around doing nothing for 3 weeks covered in snow.
07-12-2016, 02:09 AM #1
07-12-2016, 02:12 AM
More likely the ballast. I would try swapping the ballast to the other side and seeing if the problem moves.
07-12-2016, 02:12 AM #2
alamkhan3980
07-12-2016, 02:15 AM
I just had the same issue on my GF Golf. The HID eventually stopped working.
The cause of my issue was a failing ballast. I replaced the ballast and all working now.
[SIZE="1"]Lexus IS300 Navigator
Engine: ITG ProFilter, Joe-Z Intake Pipe, Custom HKS Super Drager Exhaust, TRD Oil & Rad Cap & Grounding Kit
Suspension: BC Racing Coilovers, Hotchkis ARB's, Chassis Braces & WIM Geometry
Wheels: 18" OZ Ultraleggera & Falken ZE912 Tyres
Styling: Seibon Carbon Fibre Bonnet, Figs Bonnet Struts, Sports Grill, Repositioned Horns & SS Dials
ICE: JVC KW-AVX720 HU, Hifonics ZXI 6410 Amp, MB Quart RUA 216 2-Way Components, StealthBoXz with Infinity 12" Sub & Reverse Camera[/SIZE]
alamkhan3980
07-12-2016, 02:15 AM #3
07-12-2016, 02:26 AM
is your HID relay driven or direct to the ballast?
07-12-2016, 02:26 AM #4
07-12-2016, 02:33 AM
If it's a failing ballast that was pretty quick! Although that is a better problem than an electrical fault somewhere..............yep good tip will try swapping them over.
@Stav: I'm not sure, how would I tell the difference? It's the new kit I bought from HIDs4U a few months ago....
07-12-2016, 02:33 AM #5
07-12-2016, 02:56 AM
parthiban If it's a failing ballast that was pretty quick! Although that is a better problem than an electrical fault somewhere..............yep good tip will try swapping them over.
Did you have to wire to the battery or just plug it straight into the normal headlight plug?
07-12-2016, 02:56 AM #6
07-12-2016, 03:03 AM
Sparkystav Did you have to wire to the battery or just plug it straight into the normal headlight plug?
Oh, just plugged straight in Blush
07-12-2016, 03:03 AM #7
07-12-2016, 03:04 AM
not the same as the one i have then, i had a dodgy relay which caused the same problem, nevermind
07-12-2016, 03:04 AM #8
07-12-2016, 03:23 AM
Sparkystav not the same as the one i have then, i had a dodgy relay which caused the same problem, nevermind
No worries, I'll try swapping them over and then get in touch with HIDs4u to sort a replacement or something if the problem persists.
07-12-2016, 03:23 AM #9
07-12-2016, 03:27 AM
The ballast shouldn't be failing, as you say, so if it is then it must be a fault right from the start (i.e. manufacturing fault/component problem). I'm guessing a bad solder joint or marginal component that has been killed by the extended cold weather.
07-12-2016, 03:27 AM #10
Views 206
25-12-2020, 10:57 AM
Views 690
16-09-2020, 01:57 AM
Last Post by danny1377
Views 287
10-06-2020, 05:52 AM
Views 415
04-01-2020, 11:29 AM
Last Post by Dinho
Views 334
01-11-2019, 02:01 PM
Last Post by rigga
Views 471
10-09-2019, 11:55 AM
Last Post by ormi
Views 424
20-07-2019, 10:04 AM
Last Post by pauls_is200
Views 569
24-11-2018, 04:03 AM
Views 575
30-10-2018, 07:15 AM
Views 462
15-10-2018, 06:19 AM
