JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza problem with the lex this morning
09-06-2016, 06:28 AM
hi there,
got in the car this morning and the lights on the dash are going crazy.
the airbag light wont go away and sometime the door lights will keep flash and go away after a while and the TRC and ABS light will keep flashing but they went away once i strted the car. the car drives perfect without any problems.
any idea why that is?
Edited 21-07-2009, 05:05 PM by Bandit.
09-06-2016, 06:28 AM #1
hi there,
09-06-2016, 06:33 AM
Sorry can't help you mate on that but i am sure someone will be along that can help you.
Have you checked your manual?
09-06-2016, 06:33 AM #2
09-06-2016, 06:49 AM
Hmm has it rained much near you in the past couple of days?
sounds like water ingress to me
09-06-2016, 06:49 AM #3
09-06-2016, 06:54 AM
been raining for a few days stav.
any idea how to fix?
09-06-2016, 06:54 AM #4
09-06-2016, 07:05 AM
I was going to say the same as Stav. It does sound like water causing havoc with the electrics, and with all the rain we've had recently it would kind of make sense.
Try having a look at both footwell fuseboxes and see if you can see signs of water getting in there. It might still be wet given how much it has rained.
If you do find water, then you can try and dry things out with a hairdryer, and inspect the fuse board for corrosion.
But if this is the problem, you'll still need to fix the source, i.e. the water leak itself, which is presumably getting in around your windscreen somewhere.
09-06-2016, 07:05 AM #5
09-06-2016, 07:16 AM
Actually, looking again at what lights are flashing etc, it could be the main fuse box in the engine compartment that has got water in it. That's where a lot of the fuses/relays for ABS/TRC etc are located, so it would be worth checking that as well. But the footwells still seem more likely to me.
09-06-2016, 07:16 AM #6
12-06-2016, 07:08 AM
Any progress on this ?
12-06-2016, 07:08 AM #7
16-06-2016, 03:02 AM
*cough*
Asi ?
16-06-2016, 03:02 AM #8
*cough*
Asi ?
16-06-2016, 07:34 AM
sorry mate just not had a chance to get around that but will be doing it tonight
16-06-2016, 07:34 AM #9
19-07-2016, 02:05 AM
Did you manage to sort this ?
19-07-2016, 02:05 AM #10
Views 207
25-12-2020, 10:57 AM
Views 697
16-09-2020, 01:57 AM
Last Post by danny1377
Views 288
10-06-2020, 05:52 AM
Views 428
04-01-2020, 11:29 AM
Last Post by Dinho
Views 344
01-11-2019, 02:01 PM
Last Post by rigga
Views 472
10-09-2019, 11:55 AM
Last Post by ormi
Views 425
20-07-2019, 10:04 AM
Last Post by pauls_is200
Views 569
24-11-2018, 04:03 AM
Views 578
30-10-2018, 07:15 AM
Views 463
15-10-2018, 06:19 AM
