JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza More Problems.....
More Problems.....
More Problems.....
07-09-2017, 06:50 PM
not with the thermostat but with the cooling system, as it boils at a lower temp when under pressure so will be steam not liquid going around the system
07-09-2017, 06:50 PM #11
ibby
07-09-2017, 07:03 PM
ok, But I dont think the water is at boiling point as the top hose is just warm.
does it sound like I have air in the system or faulty... thermostat ?
ibby
07-09-2017, 07:03 PM #12
08-09-2017, 04:08 AM
You could do with getting the codes read with an OBDII reader to see why the engine check light is on. Could be the speed sensors, especially since you've had a front-end collision (i.e. the front sensors).
08-09-2017, 04:08 AM #13
08-09-2017, 05:16 AM
By the way, the thermostat on the IS200 is in the side of the water pump, so that's neither right at the very bottom or very top, surely ?
Diagram
Edit - ok, I guess it's at the bottom of the cooling system really, since it's taking the coolant outlet from the radiator into the water pump.
Edited 20-10-2009, 09:05 AM by steviewevie.
08-09-2017, 05:16 AM #14
Diagram
ibby
08-09-2017, 05:23 AM
steviewevie You could do with getting the codes read with an OBDII reader to see why the engine check light is on. Could be the speed sensors, especially since you've had a front-end collision (i.e. the front sensors).
When you reffer to speed sensors
Are we talking about abs ?
I actually started my car and drove it down after the collison happened!
I didnt see any lights then
ibby
08-09-2017, 05:23 AM #15
ibby
08-09-2017, 05:27 AM
steviewevie By the way, the thermostat on the IS200 is in the side of the water pump, so that's neither right at the very bottom or very top, surely ?
Diagram
Yep, Thats what I meant, at the bottom and side of the water pump :blushing:
I havent tried the heater trick!
Iam going to go do that!
ibby
08-09-2017, 05:27 AM #16
Diagram
08-09-2017, 05:29 AM
ibby When you reffer to speed sensors
Yes, the speed sensors are used both by the ABS and TRC systems. They have quite fine cabling though, which is easily damaged. If they were ok after the collision, could they have been perhaps damaged if you've had to mess around with the front wheels/suspension ? Or maybe you haven't touched that.
Would be good to get the codes checked though, so we can tell for sure.
08-09-2017, 05:29 AM #17
08-09-2017, 05:34 AM
Ibby at this stage of your rebuild i think a obd code reader some thing like this would be a worth while investement.
The one i have listed is acheap one.
http://cgi.ebay.co.uk/U380-OBD-2-II-EOBD...3ef0d29d25
08-09-2017, 05:34 AM #18
08-09-2017, 05:39 AM
^^^^ That's exactly the same one as I've got.
08-09-2017, 05:39 AM #19
08-09-2017, 05:40 AM
Steve what sort of feedback would you give this reader?
08-09-2017, 05:40 AM #20
Views 710
29-08-2022, 03:48 PM
Views 458
06-01-2021, 12:50 AM
Views 912
26-06-2020, 04:14 PM
Last Post by Matt_C
Views 674
16-03-2020, 03:55 AM
Last Post by lex2oos
Views 1,852
04-11-2019, 10:51 AM
Last Post by Stoney
Replies 45
Views 3,941
29-09-2018, 05:37 AM
Views 739
27-04-2018, 06:45 PM
Last Post by Namking998
Replies 126
Views 13,691
12-02-2018, 05:18 PM
Last Post by Andy-R.
Views 2,175
31-08-2017, 02:36 PM
