JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Intermittent HID problem
09-12-2016, 02:00 AM
My corolla seems to be doing this, i just turn them off and on and it works fine....need to get another ballst before it complety packs up!
09-12-2016, 02:00 AM #11
09-12-2016, 02:28 AM
Haven't had a chance to swap them over yet - it now works right from startup but while the engine's turning over the headlamp flickers so it is definitely pointing to a ballast problem.
I'm going to get in touch with them for a replacement before it dies completely too.
09-12-2016, 02:28 AM #12
kam05
09-12-2016, 02:38 AM
Didn't you buy a new hid system recently? Are these new ones that are failing? Not good.
kam05
09-12-2016, 02:38 AM #13
09-12-2016, 02:45 AM
kam05 Didn't you buy a new hid system recently? Are these new ones that are failing? Not good.
Yep these are the new ones, only been on the car a short while........and yes it's not good but hope it's a one-off problem........
09-12-2016, 02:45 AM #14
09-12-2016, 02:50 AM
parthiban Haven't had a chance to swap them over yet - it now works right from startup but while the engine's turning over the headlamp flickers so it is definitely pointing to a ballast problem.
One of the ones in my IS has started doing that.....looks like im gonna need two new ballasts! Rolleyes
09-12-2016, 02:50 AM #15
iLLzLex
09-12-2016, 02:58 AM
had exact same prob on the golf...but thats cause i mounted the ballast under the front bumper...after carwashes and rain it would work intermittently (the bulb that was connected to the ballast which was under the bumper)...i removed the bumper and dis-assembled the ballast...and saw moisture on the electronics board....got a hair dryer and being very careful (not to melt it) i dried the water out, and it was working fine...after i reassembled it i sealed the edges of the ballast with clear silicone....never had problems since... (hope this helps)
iLLzLex
09-12-2016, 02:58 AM #16
09-12-2016, 03:06 AM
I actually thought moisture might have been the cause of my last kit failing, which is why with this kit I've mounted both ballasts in the air, so they'll never sit in or near any standing water.........
But I think Steve might be right with this one, seeing as it's failing so quickly there must have been a problem with this right from the start. The silicone thing is a good idea though if these things are not fully waterproof.
09-12-2016, 03:06 AM #17
09-12-2016, 03:20 AM
parthiban I actually thought moisture might have been the cause of my last kit failing, which is why with this kit I've mounted both ballasts in the air, so they'll never sit in or near any standing water.........
Where have you mouted the passenger side , ive got the driverside one floating and passenger side tucked behind the fuse box?
09-12-2016, 03:20 AM #18
iLLzLex
09-12-2016, 03:23 AM
also remember, if the car has been left not touched for long in the snow it is likely that the ballast would have got cold and seein as its made from smooth shiny metal (think bathroom mirror) the heat from the engine could have caused condensation on the inside when the temp moved from low to high...jus a suggestion lol
iLLzLex
09-12-2016, 03:23 AM #19
09-12-2016, 03:32 AM
SHAHZ Where have you mouted the passenger side , ive got the driverside one floating and passenger side tucked behind the fuse box?
It's floating behind the fusebox too, probably how yours is Smile
[Image: DSC_1575.JPG]
iLLzLex also remember, if the car has been left not touched for long in the snow it is likely that the ballast would have got cold and seein as its made from smooth shiny metal (think bathroom mirror) the heat from the engine could have caused condensation on the inside when the temp moved from low to high...jus a suggestion lol
Yep I thought that was the cause too, I was away for 3 weeks and the car was covered in snow the whole time - it's possible there is moisture inside it.
09-12-2016, 03:32 AM #20
Views 207
25-12-2020, 10:57 AM
Views 696
16-09-2020, 01:57 AM
Last Post by danny1377
Views 288
10-06-2020, 05:52 AM
Views 426
04-01-2020, 11:29 AM
Last Post by Dinho
Views 338
01-11-2019, 02:01 PM
Last Post by rigga
Views 472
10-09-2019, 11:55 AM
Last Post by ormi
Views 425
20-07-2019, 10:04 AM
Last Post by pauls_is200
Views 569
24-11-2018, 04:03 AM
Views 576
30-10-2018, 07:15 AM
Views 462
15-10-2018, 06:19 AM
